removing studs from the head?
I have like 7 more studs to go (manages to get two out) and My only other alternative I have seen is to drill one of those screw removers or take a grinder and flaten two ends of it and twist it out with a vice grip.
I have already sprayed it 3 times with PB Blaster(which is a very good rust remover) and let it set each time i sprayed it for many hours, one time even for a full 24 hours. Then used a vise grip as tight as I could sqweeze it. No luck so far. If anyone has any clever ideas, let me know.(and no.. im not taking my head of and putting it in the oven!)
I have replacment bolts, so I don't plan on re-using the studs. Thanks for the help!
Your talking manifold studs right? If so, all you need to do is thread 2 nuts (the cheap metric ones from your local hardware store, not the OEM lock nuts) back to back on the stud, then put a box wrench on the inner nut and proceed to loosen. The outer nut will keep the inner nut from turning and will rotate the stud out instead.
NegativeXero
Nov 8, 2007 10:16 PM
