NUT IN BLOCK REMOVAL
Old Jul 1, 2006 | 11:29 AM
ayougo's Avatar
Default NUT IN BLOCK REMOVAL
well, i was installing my energy inserts on the front mount and my friend cranked up the power on my impact wrench while i was hammering the insert into the front motor mount ( gun was at 2.2 and he turned it to what seems like 4 ) I went ahead and gunned the bottom bolt and the left bolt holding the mount bracket onto the block. as i went for the right bolt....disaster, the bolt broke flush with block. AT 500 FOOTPOUNDS !!!! how am i going to get this out of the block ?
Old Jul 1, 2006 | 11:39 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: NUT IN BLOCK REMOVAL (ayougo)
Probably drill it out, then tap a new thread, and install a thread insert.
Try a google search under "thread insert".
Old Jul 1, 2006 | 11:52 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: NUT IN BLOCK REMOVAL (tech8)
Or you can also try this:
http://www.sears.com/sr/javasr...e=Yes
But, I kind of doubt it, since the bolt was torqued in pretty high.
Old Jul 1, 2006 | 04:38 PM
ayougo's Avatar
i know. Ive used a tap before to get these out, and even a bolt remover for those week sauce valve cover bolts...but this is a much larger bolt made out of different steal and its in there. My only concern with drilling the bolt out is depth. the angle at which the block sits makes drilling a perfectly straight hole hard without a jig of some sort.
BTW, is that the BORG ship ?
Old Jul 1, 2006 | 04:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
True, some machine shops use jigs to drill straight and for correct depth.
Yes, that is a Borg ship.
Old Jul 1, 2006 | 05:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here is a link to some tips on removing a broken bolt:
http://www.asashop.org/autoinc...h.cfm
An important tip is to center punch the bolt first.
Although your bolt is at a different location & not the same bolt, here is another link, where they are using a "drill block" to hold the drill perpendicular:
http://www.automedia.com/Threa...1tr/1
Old Jul 1, 2006 | 05:15 PM
ayougo's Avatar
Default Re: (tech8)
Time to go shopping.
Also, That borg ship is fu cking huge !!!! I wonder if they built the ship in orbit due to its shape. ( how would the borg launch a square ship ? )
Old Jul 1, 2006 | 10:34 PM
pos_cd5's Avatar
Default Re: (ayougo)
wtf is borg?! and im interested in that screw extractor kit, can you teach me how to use it"?
Old Jul 1, 2006 | 11:02 PM
ayougo's Avatar
Default Re: (pos_cd5)
The Borg are an elite society with outstanding technology. The Borg opperate around a central persona ( the borg are more machine than human ) The borg's qween..so to speak has control over the entire society....which consist of millions. To become one.....humans are assimilated.
You basicaly tap a started whole in the broken bolt, drill it just a tad and then use the reverse bit and it unscrews the bolt out.
yia.yang09
Mar 7, 2014 03:59 PM
TravisCadello
10
Sep 28, 2009 04:46 PM
grjp1988
Sep 28, 2008 05:08 PM
allmotorb18c14door
Welding / Fabrication
Mar 2, 2007 12:04 PM
gsrcivic619
Apr 8, 2004 05:30 AM
