Write up on how to remove air conditioning?
i dunno, i just started unbolting stuff. Mine didn't work anyway. But if yours does, why in the world would you wanna take it off? You'd get pelted with rocks if you if you wanted to take off your WORKING AC down here in texas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e-Roc »</TD></TR><TR><TD CLASS="quote">i dunno, i just started unbolting stuff. Mine didn't work anyway. But if yours does, why in the world would you wanna take it off? You'd get pelted with rocks if you if you wanted to take off your WORKING AC down here in texas.</TD></TR></TABLE>
I'm getting a manifold that doesn't work with a/c. But yeah, it's pretty hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juger »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
common guys he wants help in removing it not you telling him to change his mind about it..
i suck at explaining how to do this so ima pass on this one..lol
same here bro. thats how i did it only took about 30 mins too
first off do it somewhere where noone can see you if it does work because r-12 is a cfc refrigerant and probly is wats in your car and there is a reward for turning people in who vent it into open air you have to recover it into a cylinder (up to 10000$) but after you get that part over with just take your condenser out (if you have the half radiator) and start unclamping/bolting the refrigereant lines take out the compressor and your done
Ok first things first:
Do this in a garage or somewhere where no one is around and you have a good airflow. Start by unbolting the right most fitting the condensor and be prepared to step back quickly, refrigerant is going to come out. DO NOT breathe it in, unbolt until it starts to hiss and walk away. It can take up to 2 hours to drain out depending on how much you loosen the fitting. Once this is done, remove the fitting completely and start unbolting the lines. You can take every piece of the AC system off the car (cept the blower motor) without removing anything significant but the front bumper cover. Don't forget the dryer unit is located under the driver's side wheel well and looks like an oversized aluminum can..this will need to go as well
It's pretty self explanatory, just follow the metal lines and unbolt where you see nuts/bolts. The larger line on the passenger side is 2 pieces, you will see where it unbolts (splits in 2 pieces) right around the wheel well
un bolt and remove everything located or attachtded to the radiator looking thing on the driver side. hope thats simple enough for you.
i just removed my ac to put in my brothers car and i didint even look at a diagram
i held a rag over my nose and had some goggles and gloves on with a long sleeve shirt. i just kept loosning the bolt think freon was gonna come spraying out. apparently i had a leak cause no freon came out!
x2 here in georgia
x2 here in georgia
just cut the one thats attatch to the ac. it really easy. the ac one is .... Attach to the radiator looking thing on the driver side!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thats all you really need to know~
anything attach to the radiator thing on the driver side has got to go. if you disconnect everything the belt will just fall off
I'm getting a manifold that doesn't work with a/c. But yeah, it's pretty hot.</TD></TR></TABLE>
If you were my friend I'd stab you in the neck. Its like a billion degrees outside right now. One of my friends wanted to take his working ac out of his civic and we quickly sarificed him to the car gods and scavenged parts off his car.
Mikes2000civicsi
May 31, 2007 10:48 AM
Witty
19
Aug 11, 2003 07:16 AM
