getting turn signals to work after integra dash swap.
I just put an integra dash swap into my 92 hatch, and the only thing not working is the turn signals, I know there is a write up that says what wires to put together when using the integra dash harness, but i used the civic harness. I also know that the green with yellow stripe wire is the right turn signal and the green with blue stripe is the left. I tried splicing the right signal wire into a couple of different power wires but the signal just stayed on and did not blink. Does anyone know which wire I should splice my turn signals into to make them work. Thanks.
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: getting turn signals to work after integra dash swap. (streetracerof06)
well this is one of the thread's hope it helps https://honda-tech.com/zerothread?id=1053318
Re: getting turn signals to work after integra dash swap. (DBL)
yeah, I have that diagram, thats how I knew which wires were my blinker wires and which was my power wire, I just dont know where I need to wire the blinker wires to.
make sure the grounds inside the engine bay on the wore harness is tight.
something similar happened to me ,where my turn signals would not work for **** becuase they were not grounded properly.
just a thought
just a thought
plug in your stock civic hazard switch and i bet they work..assuming you did everything else right
i did this swap and got the whole cluster to work perfect but never the hazard switch and now theres a turbo timer in its spot anyways
Re: (neEven)
I have this same topic in the Integra section where someone suggested plugging in the hazards, and my blinkers worked, your idea would have worked, thanks for the reply.
streetracerof06
07-03-2006 11:22 AM
streetracerof06
06-28-2006 03:33 PM
streetracerof06
06-28-2006 03:33 PM
