what is it???
Old Jul 1, 2006 | 01:39 PM
JJ's civic's Avatar
Default what is it???
i'm trying to pull my motor and tranny out of my std and i am wondering what is the line that goes from the center of the fire wall ot the tranny near the back motor/tranny mount??? please help i'm trying to beat the rain today. it's on and off all day so far.
Old Jul 1, 2006 | 01:48 PM
aXhatch's Avatar
Default Re: what is it??? (joeny12985)
sounds to me like the speedo cable?
Is it coming out of the tranny? The VSS vehicle speed sensor is on the tranny real close to the rear mount. Has a cable that goes into the firewall at a slight angle then goes up to your gauges and such.
It should be the same in a std as an Si.
Old Jul 1, 2006 | 01:50 PM
JJ's civic's Avatar
Default Re: what is it??? (aXhatch)
yea how do i take it off.??? i'm jsut trying to pull the motor out. o and are the wired under the intake connected going from the driver side to the passanger side???
Old Jul 1, 2006 | 01:54 PM
aXhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 &raquo;</TD></TR><TR><TD CLASS="quote">o and are the wired under the intake connected going from the driver side to the passanger side???</TD></TR></TABLE>
Not sure, couldnt understand what ur saying real well.
you can take off, there should be..uhh...3 bolts, all 10mm.
2 take it apart, one takes it out of the tranny. the one that is closest to the mount, and like, lowest in the engine bay, like, closer to the ground I guess takes it out. the other 2 bolts just take it apart. then you can pull the cable off easier and not loose the little clip inside of it.
so the bolt closest the motor mount and also closest to the ground in the bolt your looking for. there was a pic in here soemplace...cuz I went to the junkyard...and stuff...ill try to find a pic.
Old Jul 1, 2006 | 01:56 PM
aXhatch's Avatar
oh yea youll need a LONG extention, like a 12" and a moveable socket (that can change angels and stuff) make it alot easier. its really a pain if all the hoses and wires are in the way, but since your taking the motor out, feel free to remove obstructions.
Old Jul 1, 2006 | 01:57 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Some pics of how the cable connects
at the bottom of this thread:
https://honda-tech.com/zerothread?id=1325930
JJ's civic's Avatar
arite thankx i'll go out side and see if i can take it off. o yea under the intake there's wires do they disconnect or are they differnt sets.
Old Jul 1, 2006 | 02:13 PM
88DXCRX's Avatar
On the wiring,the easiest thing to do
is unplug the harnesses and pull them with the engine..
Separate the connectors as outlined in yellow circles..
You will probably just have the ones on the
passenger side if it is a STD..
Old Jul 1, 2006 | 02:16 PM
JJ's civic's Avatar
Default Re: what is it??? (88DXCRX)
o i have both. but my next question is should the vss come out with out pull or do i need to twist it. becaus emy std doesn't have the screw but my dx does.
Old Jul 1, 2006 | 02:33 PM
88DXCRX's Avatar
To remove the VSS from the transmission,
[Remove the bolt and retainer..]
Blow any debris around the top with compressed air
and then soak it with a penetrating oil like PB BLASTER.
Then twist it from side to side with a pair of small vice-grips
and then pull upward and it should come out..
Old Jul 1, 2006 | 03:20 PM
JJ's civic's Avatar
i'm still trying i might keep trying or just pull the engine and leave the tranny because i dont know how to disconnect the linkages. i see on'es jsut bolted on but don't knwo about the other.
Old Jul 1, 2006 | 08:19 PM
aXhatch's Avatar
yea spray a penetrating lube on the VSS!
heat valve lube works wonders!
and twist and pull and pry your *** off. mine came out REAL ewasy, so did my friends, but they were newer. junkyard ones that we replaced (for b series swaps) came from tegs, they were a BIOTCH to get out, think 2ft long prybars and 3 ppl. and a broken windshield!
Old Jul 2, 2006 | 10:40 AM
JJ's civic's Avatar
lol well i broke the lip of the vss a little trying to pry it out and it's still in there
2000dollarzcbs
Oct 4, 2006 04:13 PM
MANDO6669
Jun 7, 2006 09:19 PM
revlimitcrx
Apr 25, 2006 11:24 AM
94_civicEx
Jul 8, 2004 09:19 AM
BigIslandBoi
May 6, 2004 06:51 PM
