Full-Race Stage I SOHC (D16Y7) plots/pics
Old Jul 1, 2006 | 12:22 PM
B18CXr's Avatar
Default Full-Race Stage I SOHC (D16Y7) plots/pics
Since it was mysteriously deleted, repost for the archives
1996 EK (D16Y7)
130K miles
Full Race Stage I (T3/04E) .63ar hot
Performer X intake manifold
RC 550's
Apexi Power FC
Magnaflow oval muffler (3inch)
Comp Clutch Stage II
SOHC automatic radiator
Walboro 255lph pump
Car was 100% stock for the baseline pull.
Turbo pull was @ 0.69bar
NOT DYNOJET NUMBERS, NOTE THE BASELINE PULL!!!!
Old Jul 1, 2006 | 12:24 PM
SL0WEGG's Avatar
Default Re: Full-Race Stage I SOHC (D16Y7) plots/pics (B18CXr)
didn't you post this like 2 weeks ago?
Old Jul 1, 2006 | 12:49 PM
95GSRTT
Guest
Posts: n/a
Default Re: Full-Race Stage I SOHC (moops vs moors)
perform with the big boys? I dont know of any other motor that makes that little.
Good numbers none the less.
Old Jul 1, 2006 | 04:26 PM
Full-Race Geoff's Avatar
turn it up to 12 psi id like to see how it compares to the gt28rs
Old Jul 1, 2006 | 09:01 PM
TheHooded_Mike's Avatar
Default Re: Full-Race Stage I SOHC (Full-Race Geoff)
Does the y7 normally dyno that low (baseline) or does this particular dyno just happen to read low anyway? I thought a y7 would put out at least 105 or so... haha
edit: Sorry! Realized this wasn't on a dynojet...I read wrong. I figured that even a stock y7 would do better than that so I was shocked.
Old Jul 2, 2006 | 01:42 AM
Westrock2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">
whats the duty cycle like at max output with those 550's?
550's shouldn't even be close to being maxed out at this point...he could probably squeeze another 30-40 HP no problem.
Looks good so far. Air Fuel looks pretty safe. Looks like your wastegate was pretty much on the money, as you hit 10.14 PSI there at the very end. But it makes me wonder if your turbo was spooling as fast as it could...meaning that you didn't even hit full boost (10 PSI) till redline. And that even if you did raise the boost limit, would you even be able to hit it. If thats the case than maybe a 0.48 would be a little more fun as far as mid torque.
Old Jul 2, 2006 | 01:45 AM
SuperSi's Avatar
D16y7 Ftw . I just wish you guys could raise the boost.
Old Jul 2, 2006 | 02:51 AM
TURBODC4TEG's Avatar
Default Re: Full-Race Stage I SOHC (SuperSi.)
hey what kind of air filter is that and where can i get one, it looks like the size i need
Old Jul 2, 2006 | 07:45 AM
StockBlockRob's Avatar
Default Re: Full-Race Stage I SOHC (TURBODC4TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Looks good so far. Air Fuel looks pretty safe. Looks like your wastegate was pretty much on the money, as you hit 10.14 PSI there at the very end. But it makes me wonder if your turbo was spooling as fast as it could...meaning that you didn't even hit full boost (10 PSI) till redline. And that even if you did raise the boost limit, would you even be able to hit it. If thats the case than maybe a 0.48 would be a little more fun as far as mid torque.</TD></TR></TABLE>
30-40 hp? I'm making 330 whp on the same injectors with a little room left,lol
Old Jul 3, 2006 | 05:09 AM
B18CXr's Avatar
Injectors are @ 55% +/-
yes, the turbo is not well suited for this app. and boost level, but customer wanted..
Wastegate spring is @ 8psi then creeps to 10ish, see trace graph above.
I'd love to get a disco on this setup, but..
Just installed a Z6 tranny on this car
Made a world of difference.
Old Jul 3, 2006 | 06:46 AM
Default Re: Full-Race Stage I SOHC (StockBlockRob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockBlockRob &raquo;</TD></TR><TR><TD CLASS="quote">
30-40 hp? I'm making 330 whp on the same injectors with a little room left,lol</TD></TR></TABLE>
Maybe I should have bolded the "no problem" part
Old Jul 3, 2006 | 07:11 AM
Pro-Am 1934's Avatar
Default Re: Full-Race Stage I SOHC (Westrock2000)
As always great work Jack.
Jason
Old Jul 3, 2006 | 02:00 PM
contender's Avatar
Default Re: Full-Race Stage I SOHC (Pro-Am 1934)
how much did that kit cost you
Old Aug 16, 2006 | 06:16 PM
s2000june's Avatar
Default Re: Full-Race Stage I SOHC (contender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by contender &raquo;</TD></TR><TR><TD CLASS="quote">how much did that kit cost you</TD></TR></TABLE> x2
epic.fail
Jul 21, 2011 10:46 AM
90ZCREX
Jun 29, 2011 06:47 PM
everythingwentblack
Apr 12, 2009 10:51 PM
B18CXr
Jun 15, 2006 03:54 PM
