JRSC Install Help - Coolant Pipe Leaking - Hose Routing - B18C
Hey guys needed some help with my JRSC install on my B18C
1. Coolant is leaking. It appears to be coming from the coolant pipe behind the block towards the thermostat area. I had to "index" the inlet/outlet of the coolant pipe for the SC to clear as the instructions has indicated. Anyone had similar problems?
2. Routing coolant lines. How did you all route the lines. It was so hard to replace the oil filter. The instructions listed using one of the old hoses and use a new longer one. Instead, I used 2 long ones to add space but the with the 2 hoses plus the main wiring harness, it was really hard to put the oil filter on.
3. Factory oil cooler. The higher of the 2 fittings in the factory oil cooler is right up in the SC where the hose comming out of it is a bit crimped from the bottom of the SC. Is there a way to turn the factory oil cooler clockwise to clear the sc?
Thanks!
Thanks!
oranginal
Mar 30, 2009 07:39 AM
LudeyKrus
Aug 3, 2004 12:38 PM
Blue-Civic-Hybrid
May 23, 2003 08:45 PM
