I THINK this is right...
Old Jul 1, 2006 | 08:42 AM
JDM_EH2's Avatar
Default I THINK this is right...
Ok so after reading some of the swap threads/FAQ's for the last hour I think I have this right...but I just wanna make sure.
Swap: 99' GSR w/ Edelbrock IM
Car: 99' EK Hatch
99'-00' SI/EX Engine Harness
OBDIIb - OBDI Conversion Harness
Chipped P28 for tuning with Neptune
Thats all I need right, as far as WIRING goes right?? I just wanna make sure. I was gonna have Epic Tuning do it but I'd rather do it and learn myself. I am very good with tools, it was just the wiring that scared me a bit...but it seems like its plug and play while just extending a few wires. So im gonna do it myself. Just someone check this over and make sure I have it right. TIA!
Modified by JDM_EH2 at 10:33 PM 7/1/2006
Modified by JDM_EH2 at 11:46 PM 7/1/2006
Old Jul 1, 2006 | 09:20 AM
axtran's Avatar
you need a P72 - IAB's are on that GSR unless you swap that out with a Skunk2 Mani. And for OBD conversion you don't need it, the '99 Motor should already by OBD2. Engine Harness doesn't need to be changed either, just get plugs and add-on if and when you need to.
Old Jul 1, 2006 | 09:42 AM
JDM_EH2's Avatar
Default Re: (axtran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">you need a P72 - IAB's are on that GSR unless you swap that out with a Skunk2 Mani. And for OBD conversion you don't need it, the '99 Motor should already by OBD2. Engine Harness doesn't need to be changed either, just get plugs and add-on if and when you need to.</TD></TR></TABLE>
Sorry I should have stated this to begin with. This is my turbo motor and will have an edelbrock IM, and p28 to work with neptune. As for the harness i just want it to be as easy as possible...thats why i plan on getting an ex/si harness. thanks for the help though
Old Jul 1, 2006 | 01:00 PM
JDM_EH2's Avatar
Default Re: I THINK this is right... (JDM_EH2)
bump
Old Jul 1, 2006 | 06:32 PM
JDM_EH2's Avatar
Old Jul 1, 2006 | 06:38 PM
schardbody's Avatar
what about mounts???? dont forget about the rear mount bracket, a/c??? radiator hoses??? you are missing a bunch of stuff.
Old Jul 1, 2006 | 06:43 PM
Otherguy's Avatar
NASIOC.com
it should work but then again you had to ask to see...
Old Jul 1, 2006 | 06:47 PM
ekb16's Avatar
wut u have so far works but u dont get to get a Ek or SI harness..u can use ur stock harness and modify that to fit...as for the mounts ur gonna need 99-00 Si drive side motor mount bracket, 99-00 Si rear L bracket.
Old Jul 1, 2006 | 06:52 PM
ftcjimmy's Avatar
B-series shift Linkage
Old Jul 1, 2006 | 07:10 PM
JDM B16A's Avatar
Default Re: (ftcjimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EH2 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
HT always manage to give me a good laugh
Old Jul 1, 2006 | 07:45 PM
JDM_EH2's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">what about mounts???? dont forget about the rear mount bracket, a/c??? radiator hoses??? you are missing a bunch of stuff.</TD></TR></TABLE>
I should have made my post more clear. I am only concerned if my WIRING "ideas" are right.
lexusman83
19
Apr 11, 2009 07:40 PM
jamesknightsi
Jul 5, 2006 02:43 PM
ballplayer
17
May 11, 2005 03:45 AM
boostedblack99
Jan 26, 2003 02:54 PM
HybridGSR
Jan 11, 2002 02:44 PM
