Do you think this block is still good
Old Jun 30, 2006 | 12:28 PM
ARACER25's Avatar
Default Do you think this block is still good
You can tell the mount is broken but my question is do you think the block is still good? The guy that has the car isn't sure.
Old Jun 30, 2006 | 01:15 PM
Flexin5's Avatar
yikes. you should take off the timing cover and check that out, it looks like the part of the block where the motor mount attaches too could have been ripped out, however you might be luckey and the bolts could have just ripped out. try taking some stuff off, the upper part of the motor mount and timing cover and see where your at. hope this helps.
Old Jun 30, 2006 | 01:22 PM
ARACER25's Avatar
Default Re: (Flexin5)
I wish I could but its not my car yet and I'm not sure what capabilities the guy has. Hopefully he can confirm that the block is good and if so I'm gonna go get it. If not than I'll probably pass.
Old Jun 30, 2006 | 02:11 PM
gsr dood's Avatar
Default Re: (ARACER25)
def not man that mount stripped outt of the block with out a doubt. same **** happened to my old car wen i got into an accident
Old Jun 30, 2006 | 02:12 PM
gsr dood's Avatar
Default Re: (gsr dood)
woops....the block is good you just gottta get it rethreaded
1993-eg1
May 1, 2010 03:23 PM
DCTegg
Aug 23, 2009 12:00 PM
oldskoolracer
Welding / Fabrication
Feb 2, 2006 11:35 PM
stickyfingers
13
Feb 8, 2005 04:50 PM
5STAR3
12
Oct 21, 2004 03:42 PM
