bogging when idle a minute..
Old Apr 18, 2002 | 11:24 AM
-K3-'s Avatar
Default bogging when idle a minute..
If i stop at a long redlight, then try to take off, my rex feels like its taking off in 3rd but after i give it some more gas it will go away and drive normally.. i took my rex to get a full tune-up and smog(passed perfectly) and the mechanic said he thinks its one of the injectors that are going bad.. what do you guys think? i was told by my friend to buy some injector cleaner or something.. does that stuff work? Thanks
Old Apr 18, 2002 | 02:26 PM
-K3-'s Avatar
Default Re: bogging when idle a minute.. (-K3-)
please, one at a time
Old Apr 18, 2002 | 07:19 PM
-K3-'s Avatar
Old Apr 18, 2002 | 07:23 PM
Old91CivicGuy's Avatar
New User
........does your car shake like mad a lights? if it does, one of your cylinders is out. yes, the injector cleaner works. I would suggest you buy the high concentrated stuff. Can you please explain in more detail what's up w/ your car? clutch may be bad, fuel filter, fuel pump, etc. give me some more info.
Old Apr 18, 2002 | 07:39 PM
-K3-'s Avatar
Default Re: bogging when idle a minute.. (Old91CivicGuy)
it runs perfectly 99% of the time.. it does it atleast 1 time per drive, but i dont think its ever done it twice.. it happens when i'm idle for a long time(over 1 minute etc..) i sorta feel when its gonna happen cause the rpms drop a little, then when i try to take off it sputters(like i'm running on 3 cyl.) for about 2 seconds(it goes away faster if i rev it up) need any other info? thanks
no, it doesnt shake(only a little when the rpms drop to 850, but it goes away in a couple of seconds)
[Modified by -K3-, 4:42 AM 4/19/2002]
Old Apr 18, 2002 | 07:42 PM
89 CRX SI's Avatar
Ive seen a lot of hondas do that only when its in long term idle. The choke kicks in and out ... Thinks its going to stall out then chokes it and brings back up rpms. d
Old Apr 18, 2002 | 07:44 PM
New User
is your car manual or auto? when was the last time you replaced your clutch?
-K3-'s Avatar
Default Re: bogging when idle a minute.. (89 CRX SI)
i'll try some injector cleaner tomorrow and post my results. thanks
- CRX 89 Si - manual
[Modified by -K3-, 4:44 AM 4/19/2002]
Old Apr 18, 2002 | 07:55 PM
New User
oh, and use 93 octane gas. no 87 crap.
Old Apr 18, 2002 | 08:09 PM
89 CRX SI's Avatar
My old car did that. I just heel toe braked when it started that
Austin Britton
Sep 4, 2017 06:24 AM
StockDC2
Mar 31, 2013 07:30 AM
96b18c
Nov 19, 2009 08:59 AM
19stealth91
Jul 25, 2004 09:12 PM
maxxdout
Jun 21, 2002 06:04 AM
