Tranny/Clutch Problem - happend last night
Old Jun 29, 2006 | 05:49 AM
The Weather Man's Avatar
Default Tranny/Clutch Problem - happend last night
How's it going gents.
Alright - last night, i was racing as i always do.
On the way to shifting to 4th gear, my gear kinda got stuck half way in gear - and my car revved to atleast 10,000 and stayed there until i got it out of the gear.
Here's the thing.
My car goes into gear when the car is off. Its hard getting into first when the car is off though.
When the car is running - i can't get it into first.......so i have to put it in first before i start the car.
I can shift, but its kinda difficult getting into gears. I have to rev match it before it will go in.
Since the clutch is working obviously - i'm going to rule out the master cylinder.
Since the clutch isn't stuck to the floor, i'm going to rule out the slave
I'm really thinking pressure plate or throwout bearing.
What does everyone else think?
Its driveable, barely.
Oh, the clutch is only a couple months old.
It was an xtd 6 puck ceramic w/pressure plate and what not.
I don't think its the tranny because i can get into gear fairly easily when the car is off. Just first gear is a bitch to get in.
Old Jun 29, 2006 | 06:01 AM
AndyD's Avatar
Default Re: Tranny/Clutch Problem - happend last night (The Weather Man)
I still think it is your clutch.
Old Jun 29, 2006 | 11:42 AM
KENLUDE97's Avatar
Default Re: Tranny/Clutch Problem - happend last night (AndyD)
I'm with AndyD those symptoms are very similar to when min did this...
http://i6.photobucket.com/albu...2.jpg
Good luck
Old Jun 29, 2006 | 12:01 PM
93ludesitec's Avatar
Default Re: Tranny/Clutch Problem - happend last night (KENLUDE97)
that was scary as hell man, LOUD, i hope its just the throwout bearing.... if it is i have an oem one at my house still i think... we'll fix it....
Old Jun 29, 2006 | 02:17 PM
mgags7's Avatar
im in with them, im pretty sure its the clutch....
Old Jun 29, 2006 | 04:52 PM
yOnKiNaToR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote">I'm with AndyD those symptoms are very similar to when min did this...
Good luck </TD></TR></TABLE>
sounds just like my problem. and the pic looks just like my clutch. what kinda clutch is that kenlude? i happen to have an ebay oem exedy and mine is expletived.
like i said before: if there are no leaks in the master and slave cylinder, and you see then when the clutch is pushed in the slave cylinder has full movement, then it MUST be either flywheel, clutch, pressure plate, or transaxle. more than likely, it's what everyone else is saying and is the spring popped out of the clutch. the spring gets in the way and doesn't let the clutch disengage. this basically allows you to drive but without a clutch. that's why you must rev match to shift up AND down.
Old Jun 29, 2006 | 05:05 PM
akstunt600's Avatar
you my friend broke a clutch spring
Old Jun 29, 2006 | 09:29 PM
jdmlude_dude's Avatar
Default Re: (akstunt600)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akstunt600 &raquo;</TD></TR><TR><TD CLASS="quote">you my friend broke a clutch spring</TD></TR></TABLE>
Old Jun 30, 2006 | 05:28 AM
SKDRCR's Avatar
yep, either that or the disc is shredded.
Old Jun 30, 2006 | 11:33 AM
ragethemachine86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man &raquo;</TD></TR><TR><TD CLASS="quote"> my car revved to atleast 10,000 and stayed there until i got it out of the gear. </TD></TR></TABLE>
shouldnt the clutch be the least or ur problems now? the engine didnt blow?
Old Jun 30, 2006 | 12:14 PM
98TypeSH's Avatar
Default Re: Tranny/Clutch Problem - happend last night (ragethemachine86)
is it a 6 puck sprung or unsprung ?
Old Jun 30, 2006 | 04:50 PM
snobordboy's Avatar
Moderator
Default Re: Tranny/Clutch Problem - happend last night (98TypeSH)
Sounds like when I blew springs in my clutch also!
Old Jul 3, 2006 | 05:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">is it a 6 puck sprung or unsprung ?</TD></TR></TABLE>
sprung
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 &raquo;</TD></TR><TR><TD CLASS="quote">
shouldnt the clutch be the least or ur problems now? the engine didnt blow?</TD></TR></TABLE>
Nope. Engine is just fine.
Oh, i think its the pressure plate still. I took the car out for a drive yesterday, and found out that I can shift without using the clutch. So, i'm thinking it has to be the pressure plate or TOB. I doubt the disc is shredded or anything - but i guess its a possibility. we will know soon enough.
Old Jul 3, 2006 | 06:43 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
told you bought racing every week lol...was it worth it?? did you get that 14.1???? anyway I'm going with a broken spring also...throwout bearing would make lots of noise when shifting or wit hno load......hmmmmmmmmm
Old Jul 3, 2006 | 08:30 AM
Default Re: Tranny/Clutch Problem - happend last night (I got the CD5 Jeebies!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">told you bought racing every week lol...was it worth it?? did you get that 14.1???? anyway I'm going with a broken spring also...throwout bearing would make lots of noise when shifting or wit hno load......hmmmmmmmmm</TD></TR></TABLE>
how about almost every day
yeah, its my fault though.
92sully
Sep 6, 2010 01:18 PM
SpoonCivicSir20
Oct 13, 2008 08:13 AM
t0mmysays
Jul 6, 2006 10:21 PM
The Weather Man
Jun 29, 2006 09:44 AM
JDMflavor_EJ
Jul 12, 2004 09:41 PM
