What is this hole?!?!?!?! HELP PLZ!! SEARCHED!!
I'm in the last stages of putting my motor together, what is this hole for? I have it currnetly sealed off but I kinda need to know. Thanks.
It opens up to the crankcase I believe. I know the big hole to the right of the oil filter connection does. What you have there might be a plug that opens up to the water jacket. Sometimes this thing is called a "freeze plug" and removed when installing block heaters in the northern states.
looking closer, I don't think it's a freeze plug. I think it opens to the crank case just like the hole to the right. Just leave it plugged.
Here's my B16A. It's plugged there too. Just leave it alone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INCNTRL4 »</TD></TR><TR><TD CLASS="quote">Sweet thanks. and its a b20 dart block
Dart block -fap fap fap fap-.
</TD></TR></TABLE>Dart block -fap fap fap fap-.
I believe the Dart block uses a different plug than a Honda block, if I remember right I had to use a 3/4" NPT fitting on mine, but check the threads to be sure because I could be hallucinating again. I used both those holes for crankcase ventilation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOC-US 2K »</TD></TR><TR><TD CLASS="quote">The plug on the top right if for the factory oil cooler option. The one on the bottom left is a clean out plug.</TD></TR></TABLE>
I know. I had that thing circled from a previous question, and that pic was the only one I had online at the time.
The DX Rex
Jul 25, 2010 12:36 PM
SkoundrelUSA
Aug 23, 2006 08:42 AM
