how do you put AN fittings onto ss line? I dont get it
Old Jun 28, 2006 | 06:29 PM
teg racer 877's Avatar
Default how do you put AN fittings onto ss line? I dont get it
this is probly a really dumb question but I cant figue out how to put my oil return line together, its from fastturbo.com so I think there earls fittings? I tryed just pushing the line in really hard but all it does is scratch the anodizing off and its far from sliding right in, am I missing something?
Old Jun 28, 2006 | 06:33 PM
komat's Avatar
Default Re: how do you put AN fittings onto ss line? I dont get it (teg racer 877)
strip the ss braided off
Old Jun 28, 2006 | 06:37 PM
Default Re: how do you put AN fittings onto ss line? I dont get it (komat)
so its tapered at the end? how? with a dremel or something?
Old Jun 28, 2006 | 06:39 PM
crxrocks's Avatar
When I installed a -10AN fitting on my -10AN line you didn't have to cut any of the metal. You just forced it in to the little line on the fitting.
komat's Avatar
sure
Old Jun 28, 2006 | 06:41 PM
willyboyK20's Avatar
you have to wrap the end of the pipe with tape and push and twist like a *****
The best way is to use a bench clamp and twist on with a wrench.
Old Jun 28, 2006 | 06:43 PM
Default Re: how do you put AN fittings onto ss line? I dont get it (willyboyK20)
oh ok, I think I got it, thanks.
Old Jun 28, 2006 | 07:12 PM
AbitAvenger's Avatar
oil the fitting and the inside of the tube, shove it halfway in there, screw the fitting on halfway, shove it in and as far as it can go, then tighten the bitch down
Old Jun 28, 2006 | 07:14 PM
eg crunkmonster's Avatar
Default Re: (AbitAvenger)
use some WD-40 to lube it and twist it in
Old Jun 28, 2006 | 07:17 PM
mike93boost's Avatar
my fast-turbo kit came with very detailed instructions....why dont read them?
Old Jun 28, 2006 | 08:09 PM
Default Re: (mike93boost)
mine dident come with no directions!? hmm... eh its cool, il figure it out, thanks for the help everyone
Eppo
Jul 1, 2011 09:53 PM
jsnm
Mar 3, 2005 01:29 PM
DEVIN22CBR
Feb 5, 2004 04:08 PM
reignofchaos
Jul 27, 2003 10:34 AM
jthelman
Sep 11, 2002 01:49 AM
