tig torch help
Old Jun 28, 2006 | 05:54 PM
all_motor_mike's Avatar
Default tig torch help
what torches are u guys running here. i just looked at a hole **** load on line and i have no idea what would be good for me. i want one for basic stuff where there are no tight places etc. and a i want a smaller one for the tighter spots. i also want to be able to get the "long" narrow cones for both torches to get down into collectors and stuff like that. i saw 9's, 10's, 16's, 17's, 24's, 26's could anyone give some insight on what differs in these torches? they were a CK torches by the way.
Old Jun 30, 2006 | 09:43 AM
Default Re: tig torch help (all_motor_mike)
anybody?
Old Jun 30, 2006 | 12:17 PM
ManBearPig4silly's Avatar
Bigger numbers = bigger torch.
I have an air cooled #17.
I hear a flex head #9 is mint for tight places. I think there was a post called "check out my new torch" or something like that which had pics of a super small flex head torch with a tiny as **** butt cap. I want one of those.
Old Jun 30, 2006 | 12:31 PM
Pikachu's Avatar
The normal torch is a CK 17. You are probably looking for lava nozzles for that long tip. The problem with that is that the nozzle is expensive and it does not fit a CK 17. Personally, just get a big cup and pull out the tungsten a bit.
Old Jun 30, 2006 | 01:27 PM
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">The normal torch is a CK 17. You are probably looking for lava nozzles for that long tip. The problem with that is that the nozzle is expensive and it does not fit a CK 17. Personally, just get a big cup and pull out the tungsten a bit.</TD></TR></TABLE>
You will need a lense to do that effectively as well.
Local
Jun 22, 2011 12:45 PM
Pikachu
Welding / Fabrication
Feb 10, 2007 07:45 PM
Muffler Bearing
Honda Motorcycles
11
Dec 11, 2004 09:51 AM
oMek
Apr 20, 2004 11:26 PM
navin
154
Nov 14, 2003 06:38 AM
