wanted to make sure b4 i tried it...PSI question
Old Jun 28, 2006 | 04:59 PM
krazyhmongboi's Avatar
Default wanted to make sure b4 i tried it...PSI question
i've read/heard that you can add washers between the turbo and the wastegate on internal wastegated turbo's to get more psi..is this true?..how do you add more psi's aniway?
Old Jun 28, 2006 | 05:12 PM
beepy's Avatar
Default Re: wanted to make sure b4 i tried it...PSI question (krazyhmongboi)
If the wastegate actuator is bolted to the bracket, then yes. You can add washers between the actuator and the bracket.
Old Jun 28, 2006 | 05:13 PM
dcturbols's Avatar
1. I don't deal with internal wastegates so I dunno about the washers idea. I do know you can get adjustable internal wastegates.
2. You add "psi's" with MaDD VTEK BOOST powa yo.
3. Search I am sure this has been covered (either on H-T or on google).
SiR99
Mar 28, 2006 03:28 PM
Ad4mGSR
Jul 12, 2004 11:51 PM
swift535
Apr 24, 2004 05:01 PM
turbodelsolman
Mar 13, 2003 08:07 PM
