Intermediate shaft for d16
Old Jun 28, 2006 | 01:03 PM
instructor74's Avatar
Default Intermediate shaft for d16
I have a 93 Si. I am looking for an intermediate shaft that will work with the d16 shoc to let me run equal drive shafts.
Old Jun 28, 2006 | 01:06 PM
FalkenSiR's Avatar
Default Re: Intermediate shaft for d16 (instructor74)
Contact companies that carry JDM D15B motors, because that is the only D series tranny that came with equal length axles. So basically you want the whole D15B setup
Old Jun 29, 2006 | 04:23 AM
Default Re: Intermediate shaft for d16 (fast95eg8)
thanks for the info I will give them a try
Old Jun 29, 2006 | 04:27 AM
the jdmchop's Avatar
i belive the dohc D series from the first gen integra came with a half shaft
wasnt aware the d15bvtec came with them also
but the zc motor form the first gen is a cable so that sucks
Old Jun 29, 2006 | 04:36 AM
Default Re: Intermediate shaft for d16 (anti-lag aka JDMCHOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anti-lag aka JDMCHOP &raquo;</TD></TR><TR><TD CLASS="quote">i belive the dohc D series from the first gen integra came with a half shaft
but the zc motor form the first gen is a cable so that sucks </TD></TR></TABLE>
I dont need the trans as long as the splins on the intermediate shaft are the same
Old Jun 29, 2006 | 04:40 AM
you may have to run the zc diff for the axles or somethign like that!
i know full-race did that for there sohc PINKS car
Old Jun 29, 2006 | 05:30 AM
you might be right but first I will have to find one. Then I will make it work.
Old Jun 29, 2006 | 05:34 AM
how much power are you making that you need equal lenght axles if i may ask?
Old Jun 29, 2006 | 08:42 AM
a little above stock but I auto x the car and I can't stand having the torque steer that is in the car under heavy acceleration
Old Jun 29, 2006 | 10:09 AM
you sure the axles are the problem?
try a lsd or do you have one already?
Old Jun 29, 2006 | 10:44 AM
court's Avatar
25 Year Member
you can use the zc midshaft/ make sure its a 90+
Old Jun 29, 2006 | 11:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anti-lag aka JDMCHOP &raquo;</TD></TR><TR><TD CLASS="quote">you sure the axles are the problem?
try a lsd or do you have one already?</TD></TR></TABLE>
Already runing an lsd this is just something that has bugged me since the car was new.
Old Jun 29, 2006 | 11:09 AM
gotchya!
Old Jun 29, 2006 | 11:51 AM
anyone know the part number for that shaft i have done some digging and looking but had no luck or even model and year that might have it in it
Old Jun 29, 2006 | 11:56 AM
the first gen integras have them the d16a1 i belive aka ZC
i know full-race used it on there PINKS car look for the thread it might say what exactly they used , if not pm on of the f-r people and i bet they can head you into the light!
Old Jun 29, 2006 | 01:03 PM
thanks again for the info
Old Jun 29, 2006 | 01:18 PM
Natural Aspirations's Avatar
I think the 90 Civic 4WD also had a Halfshaft, may want to check it out as it is most likely to have the correct setup.
Old Jun 29, 2006 | 01:58 PM
Default Re: (crixzc)
agin hes running a hydro tranny and the half shadts came on the cable ones
time to swap in the zc diff!
Old Jun 29, 2006 | 02:28 PM
Slamaccord's Avatar
Default Re: (anti-lag aka JDMCHOP)
Would axles be a pain to come by in the long run ?
Old Jun 29, 2006 | 02:33 PM
Default Re: (Slamaccord)
i dont think first gen integra axles are hard to find
Old Jun 30, 2006 | 02:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anti-lag aka JDMCHOP &raquo;</TD></TR><TR><TD CLASS="quote">agin hes running a hydro tranny and the half shadts came on the cable ones
time to swap in the zc diff!</TD></TR></TABLE>
Insnt the ZC also CABLE? Im missing the difference between the hydro and cable axles. I do not know any difference but I could very well be wrong. I was prety sure the diff would not swap.
Old Jun 30, 2006 | 02:16 PM
Bense's Avatar
I have a half shaft that came off of a jdm sohc carb'd integra zxi.
aka the "zc midshaft"
this allows you to run the equal length axles, however it requires that you run a different differential. Be it the regular zc diff or a zc lsd.
either way, I have the halfshaft and a non-lsd zc diff. Which is what the "PINKS" SOHC civic ran.
I'll let both go for rather cheap, I want it gone!
Old Jun 30, 2006 | 03:15 PM
schardbody's Avatar
yeah, you have to either do the hydro to cable conversion and run a cable zc trans or buy the diff and all and swap into your hydro trans. i will vouche for "bense" if needed, dont see why though, LOL"
civic46
Oct 24, 2007 10:42 AM
D21X
Sep 23, 2004 10:31 AM
EH3-R
Nov 6, 2003 09:25 AM
jesselee
Apr 11, 2003 12:37 PM
