wiseco pistons
Old Jun 26, 2006 | 09:06 PM
ekVtecPower's Avatar
Default wiseco pistons
im fixing to order some.. but lol i dont know wut bore size my LS (B18B1) block is.. im guessin its 81 mm ??
Old Jun 26, 2006 | 09:12 PM
zerovandez's Avatar
Yes, it's 81mm. But if your going to throw in new pistons it's always advisable to bore it out to 81.5mm (.020") over and get pistons to match it to ensure each cylinders roundness. Someone correct me if I'm wrong....
Old Jun 26, 2006 | 09:17 PM
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it's 81mm. But if your going to throw in new pistons it's always advisable to bore it out to 81.5mm (.020") over and get pistons to match it to ensure each cylinders roundness. Someone correct me if I'm wrong....</TD></TR></TABLE>
i kinda get what ur saying.. so since its 81mm .. and i get the 81.5mm... then take my block and give the people one of my piston to match it up nice and tight while my block get honed. should work great right?
Old Jun 26, 2006 | 09:28 PM
Default Re: (ekVtecPower)
Old Jun 26, 2006 | 10:37 PM
zerovandez's Avatar
Your block is 81mm now. If you get pistons, Get some really good ones like CP. Get your block bored/honed to 81.5(.020")over. Then purchase the pistons to the EXACT size as the bore. Here's a link for you to read up on engine building.
http://forums.evans-tuning.com/viewtopic.php?t=326
Old Jun 26, 2006 | 11:14 PM
Ruben19's Avatar
you dont need really good pistons like cp.
get some p30 or ctr pistons. they will do the same job.
what is your set up.
all motor or turbo
Old Jun 26, 2006 | 11:44 PM
Default Re: (Ruben19)
thanks for that write up mannn..really appricate it.. but i can pretty much afford wiseco pistons.. CP's are to expensive.. but yea my set up is a b18b1 turbo.. im rebuilding everything.
Old Jun 27, 2006 | 10:58 AM
zerovandez's Avatar
and follow that link to your best. Everything in that article you will need to replicate. Engine building is not like toy model building, be very precise and don't cheap out on it either cuz you'll pay for it in the long run.
Old Jun 27, 2006 | 11:18 AM
wiseco is what im getting.
GT500FTW
Engine Machining & Assembly
Jun 14, 2015 10:52 AM
evade this honda
Jul 28, 2006 07:20 PM
delacampos
Dec 2, 2004 01:26 PM
743power
Mar 2, 2002 03:16 PM
tysir
Aug 16, 2001 08:32 AM
