Car Overheating issues???
Old Jun 26, 2006 | 04:00 PM
NsX_CrX's Avatar
Default Car Overheating issues???
Hey ht's. I was tapping about 6k on 5th gear for a minute or two and next thing i know, my temp gauge was very close to the max. marker. Had to slow down immediately. Does that mean that something has failed or is it normal due to the conditions and the amount of time the engine was working so hard?
Old Jun 26, 2006 | 04:28 PM
wheelmanbg's Avatar
Default Re: Car Overheating issues??? (NsX_CrX)
if you were moving then it shouldn't overheat
I'd look into it
Old Jun 26, 2006 | 04:34 PM
EK79's Avatar
Default Re: Car Overheating issues??? (wheelmanbg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote">if you were moving then it shouldn't overheat
I'd look into it</TD></TR></TABLE>
not true you car still can overheat even if moving a fewthings to check
1. thermostat (is it time for a new one)
2. fan switch ( same deal)
3. timing.............is it set correctly
4. local temperature and aggressive driving conditions can hurt the temp as well
5. is fan even coming on?
next time you experience this turn the heat on full blast and see if it cools down
good luck.
Old Jun 26, 2006 | 04:40 PM
mathieucivic's Avatar
Default Re: Car Overheating issues??? (EK79)
Check your radiator.
80% chance is the problem.
Old Jun 26, 2006 | 04:51 PM
wheelmanbg's Avatar
Default Re: Car Overheating issues??? (mathieucivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK79 &raquo;</TD></TR><TR><TD CLASS="quote">
good luck. </TD></TR></TABLE>
if he hit 6k in 5th that means he was going 100+
I don't think the fan would be a factor at that speed
Also what car is this?
And yeah, I agree with the radiator call. You can have it flushed or just buy a new one
Old Jun 26, 2006 | 04:54 PM
Slamaccord's Avatar
Radiator X3
Old Jun 26, 2006 | 11:08 PM
NsX_CrX's Avatar
Default Re: Car Overheating issues??? (Slamaccord)
Thanks for the reply guys. Well, it's a hatch with a b18c1, and yeah, i was hitting around 125. I've changed my water pump, etc, before I put the motor in, but i still have my hatch radiator and i did forget to change the thermostat. But I didn't think that it would matter that much, and again, i haven't gone at that speed and condition for that amount of time. The temperature was about 80 degrees and fan does come on. Timing is also correct and I am using a stock ECU. Will change radiator, hoses and thermostat and see what would happen if i get another chance.
Thanks for the help guys.
Old Jun 27, 2006 | 02:44 AM
Ohh...Uhh...'s Avatar
Not that doing all that preventive maintenance is bad. But why don't you just flush the radiator first and change the hoses and thermostat before actually buying the radiator? Might save some money.
Old Jun 27, 2006 | 02:48 AM
fmrprojects's Avatar
Default Re: Car Overheating issues??? (Ohh...Uhh...)
get a koyo or fluidyne while you are at it
91prelude4me
Jun 29, 2014 04:21 PM
RuneRavenX
Apr 2, 2013 04:45 PM
walrus_07
Feb 21, 2009 10:16 PM
-Championship-
Feb 18, 2007 08:00 PM
ITRacer121
Feb 1, 2005 10:24 AM
