HELP WITH DRAG KIT INSTALL
Old Apr 17, 2002 | 08:37 PM
DeDonDeRosa's Avatar
Default HELP WITH DRAG KIT INSTALL
hey whats up i was wondering if i can get some help on my gen 3 drag kit install on my 97 gsr i was wondering if anyone has pix of there setup or can help me with with the return line for the oil pan IM LOST!!!!!
so i was wondering if someone can help me out and get me some pics
so i would appreciate it if i can get some help on tapping the oil pan!
thanks a lot
Old Apr 17, 2002 | 08:45 PM
PrecisionH23a's Avatar
Default Re: HELP WITH DRAG KIT INSTALL (DeDonDeRosa)
for your oil pan, you need to have the oil return line TIG welded. When your manifold and turbo are on, eyeball where the oil return line needs to be on your oil pan then mark the pan. drill a hole in it. clean it up nicely then take it to a shop and have it tig welded. this might be some help for you....
http://people.clemson.edu/~averma/Pr...urbo/turbo.htm
Old Apr 17, 2002 | 08:57 PM
SIK IN DA HED's Avatar
New User
Default Re: HELP WITH DRAG KIT INSTALL (GudeH23a)
do it right the first time. ask DUSTIN for a link to his website. he has a lot of pics on his installation. im pretty sure he has a few shots of the return line.
Old Apr 17, 2002 | 09:44 PM
2K_TEG's Avatar
Default Re: HELP WITH DRAG KIT INSTALL (dlplayboy)
dustin's pictures Take a look around there.
Old Apr 17, 2002 | 10:22 PM
turbopimp's Avatar
don't forget to have your downpipe temporarily on to make sure there will not be any interference with the oil return...
Old Apr 18, 2002 | 12:26 AM
b18bvudoo's Avatar
New User
Default Re: HELP WITH DRAG KIT INSTALL (turbopimp)
yeah i would mount everything to make sure yor return line has a clear path. i wouldnt recommend this but i used jb weld on my oil pan. i dont have leaks so i guess i'm lucky.
Old Apr 18, 2002 | 12:38 AM
FBP Si 2000's Avatar
Default Re: HELP WITH DRAG KIT INSTALL (vudoo666)
Ditto, I used JB weld also...no leaks so far...
rudebwoy
May 21, 2005 12:28 PM
...emu...
Jul 22, 2004 07:17 AM
UsaTLinh
Jun 2, 2004 10:58 PM
HybridKOOP
Jan 22, 2004 03:56 AM
vtecpwred
Apr 9, 2003 10:58 AM
