Oil drain leak!!! small but need help .......
This is the problem. I have a max rev turbo kit so it comes with I think aromotive or earls fittings. So they give you a fitting to weld on the pan took it to a no name shop to get it welded soo sorry I did that. But it is done now so leaked through weld ok I will just honda bond it up. Worked better than nothing but still leaks I have hondabonded the fitting on the pan and the earls fitting to still is wet with oil but not dripping just has oil around the honda bond. please help any sugestions other than getting new pan please low on funds.... Thanks a bunch............
leaks suck *****....
Re: Oil drain leak!!! small but need help ....... (SiRkid)
need help to do the job on the car not take the oilpan off and so on so on there got to be a good product out that can help me with my problem.
Re: Oil drain leak!!! small but need help ....... (vtecpwred)
Re: Oil drain leak!!! small but need help ....... (ion_four)
Just want a fix for now low on money that is the problem. I am going to get the morroso oil pan later. Sorry for the spelling on moroso i think i dont know thanks
i dont know about any quick fix ways but if you talk to Sonny (i think it was him) he can give you details on a weldless oil return. he has pictures too which clarifies everything. if i was to expalin it to you i would probably confuse the hell out of you. it is was i used and the thing is clean as hell.
it will cost you about $70 or so. good system tho!
New User
Re: Oil drain leak!!! small but need help ....... (dirtySOHC's)
I had several battle missions againts my oil return line. Like you, i took my **** to get welded at a no name place. The guy rewelded it three freaking times and it was still leaking! There must have been several small tiny holes he didnt get. Either way oil can seap out of there.
Basicaly do this, drain the oil and clean the area around the fitting with brake cleaner, or something that cleans very good. Get your self some JB weld and splat that stuff all around the fitting. Follow the direction when it comes to letting it dry. Ever since then, mine has never leaked. And this cost about $5
JB WELD RULES
JB WELD RULES
Re: Oil drain leak!!! small but need help ....... (lshatchturbo)
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: Oil drain leak!!! small but need help ....... (Racerage1)
What are JB welds? I have never seen them before.
Re: Oil drain leak!!! small but need help ....... (Snafu-Si)
ur on honda-tech and never heard of jb weld lol...h-t people use it to fix everything. Its really strong epoxy type stuff that sticks to anything. Ive seen it used on intercoolers, bov's, oil pans, etc. I wouldn't really recommend it for long term use on such a vital part of ur turbo system but the stuff works wonders.
