TDC
Ok I just did a fresh rebuild on a d16z6 motor and Im just making sure I got it right, when Im setting the crank and cam position, is it the cam and crank both in the Up position, or the cam up, and the crank a few degrees ATDC??, My helms manual says my crank should have 2 notches one for TDC and one for timing but im only seing one?? any help?
I got everything back together the other day, But Im having some "timing issues"
and it wont fire, If you are looking at the cap from the drivers side cylinder 1 is the one in the 9 o'clock position and it goes clockwise from there, 1-3-4-2 is the firing order I believe Im right there. I just think My cam and or crank timing is off..
doesn't a z6 came line up with the block, using teh two marks on the cam..and the crank is the lone mark on the pulley lined up using the timing cover marks or a marking on the oil pump.... Y8 is wat i got
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPinkEye »</TD></TR><TR><TD CLASS="quote">doesn't a z6 came line up with the block, using teh two marks on the cam..and the crank is the lone mark on the pulley lined up using the timing cover marks or a marking on the oil pump.... Y8 is wat i got</TD></TR></TABLE>
correct, the crank timing mark is on the timing cover looking down at the pulley you will see the mark that lines up w/ the lone mark on the crank pulley. the cam gear has the UP mark towards the top and the two hashes on the sides lined up w/ the top of the block bottom of the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">
correct, the crank timing mark is on the timing cover looking down at the pulley you will see the mark that lines up w/ the lone mark on the crank pulley. the cam gear has the UP mark towards the top and the two hashes on the sides lined up w/ the top of the block bottom of the head. </TD></TR></TABLE>
thxs, but for the verification...(since i'm suspecting this...) the Y8 uses an arrow on the back timing cover to set timing against the left mark cam, right lol...i ask since i set it using this mark..car bogs, but i think it's else where..
EKB18BPR3
Dec 25, 2003 03:21 PM
