Bent Valve Inspection....
Old Jun 25, 2006 | 08:15 AM
JDM_SOHC's Avatar
Default Bent Valve Inspection....
Basically simply stated in Topic Title.. Do I have to remove the head for inspection of all my valves... I'm hearing "click click click click click" that moves with the increase of RPM's an it goes to the rev like as I rev higher the clicks move faster an louder... Or, if I leave a complete stop an go from first to third "so I can hear engine noise better to avoid exhaust noise interference" I can hear it VERY clearly... So basically yeah, easiest way to inspect valves anyone..???
I've searched and found that all people know so far, is how to tell other people to search lol...
Old Jun 25, 2006 | 08:48 AM
tatmark1's Avatar
you can do a leak down test
Old Jun 25, 2006 | 08:50 AM
JDM_SOHC's Avatar
Default Re: (tatmark1)
All cylinders should put out somewhere above 200psi right..??? Even if a valve is slightly bent will it show up on a comp test..??
Old Jun 25, 2006 | 08:55 AM
tatmark1's Avatar
your thinking comp test.leak down will tell you more but do both
Old Jun 25, 2006 | 08:58 AM
JDM_SOHC's Avatar
Wont a leakdown test just show if my head gasket an stuff are bad..?? I didntknow if it would show signs of bent valves... sorry for misunderstanding...
Old Jun 25, 2006 | 09:07 AM
tatmark1's Avatar
again your thinking compresion test
Old Jun 25, 2006 | 09:57 AM
Chiovnidca's Avatar
Default Re: (JDM_SOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">Wont a leakdown test just show if my head gasket an stuff are bad..?? I didntknow if it would show signs of bent valves... sorry for misunderstanding...</TD></TR></TABLE>
A leakdown test will tell you how much leakage there is and where it's leaking from.
Old Jun 25, 2006 | 11:40 AM
JDM_SOHC's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
A leakdown test will tell you how much leakage there is and where it's leaking from.</TD></TR></TABLE>
truu, about how much am i gonna be spending for a leakdown test..?? an is it something i could do at home or would a local mechanic be more capable..??
Old Jun 25, 2006 | 01:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_SOHC &raquo;</TD></TR><TR><TD CLASS="quote">truu, about how much am i gonna be spending for a leakdown test..?? an is it something i could do at home or would a local mechanic be more capable..?? </TD></TR></TABLE>
You need an air compressor and a cylinder leakage gauge set.
Old Jun 25, 2006 | 01:57 PM
JDM_SOHC's Avatar
You need an air compressor and a cylinder leakage gauge set.</TD></TR></TABLE>
truu i have an air compressor at home... 150psi or something, where can i buy a cylinder gauge leakage set..??? ill search also, j/w if u kno off top of ur head..
EDIT: Cuz damn, i've searched an all i seen was gauges from like $299.99 an up..!!!
Modified by JDM_SOHC at 3:38 AM 6/26/2006
potatointegra01
Apr 19, 2015 12:42 PM
SinsEvil666
49
Oct 15, 2008 11:04 PM
B20inDCinLBC
Oct 21, 2006 09:40 PM
OBRJosh
Aug 9, 2006 05:25 PM
JdmIntegra98
Jul 3, 2003 03:58 PM
