typical parts and labor charge...
whats the typical parts and labor charge for..
rings and seals
i guess head gasket as well
car is burning oil. The smoke appears to be blue. I notice it when i stay in second and rev high in the gear then let of the gas. and when im backing up as well..
i have oil on my second cyl spark plug as well..
coolant level hasnt changed
there does seem to be a little bit of a spot under my car when i park tho.
rings and seals
How many miles on the motor? Have you done a compression test? I got a headgasket for about 45 bucks. Rings from honda will run u around 110 dollars but i got hastings rings for 35 bucks
But if ur putting new rings in, u might was well take the whole motor out and take the block and head to a machine shop and get them to do their magic. Because depending on the shape of the cylinders, u might have to get it bored. And if ur just puttin in new rings the block needs to be honed. Oh and ur gonna want to put in new bearings. And while the head is off, it needs to be checked, have a valve job and get new valve seals. So...alot of money. But do a compression test first and get back to us.
