Need piston rings.. what should I do?
Old Apr 22, 2003 | 08:34 AM
riceburnah's Avatar
Default Need piston rings.. what should I do?
I have an 97 Ls with a fmax turbo, had the thing running for not even 30 minutes and having problems... pouring out smoke, oil out the exhaust and the air breather (blew the stock head gasket), installed the low compression head gasket but still my compression reads 70,150,70,60 so...it has got to be the piston rings, so this is probably a costly install so should I just buy a new block because there fairly cheap for my car?
Old Apr 22, 2003 | 08:40 AM
genop's Avatar
Default Re: Need piston rings.. what should I do? (ihaterice8)
it will cost just as much or more to install a new block besides, I wouldnt put a new motor in my car without replacing the piston rings first. Either way you wont get out of replacing the rings (if you do it right).
Old Apr 22, 2003 | 08:41 AM
b16ahybrid's Avatar
you could but you won't know the condition of those rings/pistons.
If you have the money why not build the bottom end while it's out?
I would opt to replace the rings instead of buying a new block
existanzcivicb20
Sep 29, 2014 05:33 AM
nick91civicsi
Nov 11, 2006 11:06 AM
KingOfQB
10
Mar 4, 2006 07:30 AM
xteg95
May 3, 2003 04:16 PM
xteg95
May 3, 2003 10:56 AM
