I need help
Old Jun 24, 2006 | 07:38 AM
fastbb2's Avatar
Default I need help
I have a 92 prelude with a jdm h22, skunk2 IM and dcsports header, walbro 255lph FP. my car is spitting and sputtering from idle to about 4000. The cel is on and I don't know how to check it. and it also runs very rich ( I'm talking 52psi with the vacuum line on) Someone on here told me my problem with how rich i'm running. I just want my car to run normal and not like ****!!!!!!!!!!!!!!!!! PLEASE SOMEONE HELP
Old Jun 24, 2006 | 08:02 AM
Hawkze_2.3's Avatar
Default Re: I need help (fastbb2)
You can check the code with a paperclip. Just find the little blue 2-pin connector behind the radio and stick the paperclip in both sides and the CEL will flash a certain number of times to show you the code.
Old Jun 24, 2006 | 12:06 PM
fastbb2's Avatar
Default Re: I need help (Hawkze_2.3)
thank you hawkze_2.3. now for a stupid question the light when out for a little bit then blinked 6 time real quick then went out then stayed on for a little bit then did it all over agian whats that mean
Old Jun 24, 2006 | 12:16 PM
Hawkze_2.3's Avatar
Try to find a list of Honda trouble codes for future reference, but a code 6 is Engine Coolant Temperature Sensor (ECT).
That makes sense considering the ECU uses temperature among other things to determine how much fuel to dump in...
Old Jun 24, 2006 | 12:21 PM
fastbb2's Avatar
its my injectors, when I checked the codes i thought the same thing but my friend told what it was the injectors I told him everything that the light did. But I do thank you for telling me where the plug was I called two different honda dealers and they couldn't even tell me where it was. Thanks again
Wouldn't the car over heat if the ect switch was bad
Old Jun 24, 2006 | 12:26 PM
Hawkze_2.3's Avatar
So you cleaned or replaced the injectors and that helped??
Old Jun 24, 2006 | 01:17 PM
fastbb2's Avatar
not yet I'll leat you know what happens thanks again
Old Jul 2, 2006 | 04:43 PM
fastbb2's Avatar
well hawkze_2.3 you were right it was the ect there was also another sensor that went bad as well. Finally the cel went out car runs much better thanks for you help
89luderSi
Oct 25, 2011 10:54 AM
Darkane
Jun 18, 2008 07:21 AM
superdat1
Feb 17, 2008 04:09 AM
boosted_lude
Apr 20, 2005 01:50 PM
