turbo psi set
I just put in my custom turbo kit and had a question at what psi can I go up to with a stock d16z6 motor? It is a turbonetic t3t4 turbo with a .48 AR. I'm using an evo intercooler, evo bov, eclipse dsm 450cc fuel injectors, custom pippings. Does anyone know around what hp to the wheel will I be at with the boost at 8 psi? I do really have the time to dyno it yet cause I work two jobs so I just want basic information.
Thanks
Thanks
umm..
it's hard to say, you are probably at like.. 100hp ish to the wheels stock...
untuned turbo setups don't see nearly the hp per pound that tuned setups do.. you will probably be somewhere between 155-170 at the wheels on 8psi.. that is a very very rough estimate. Figuring you will get 8-10hp per pound if your lucky. After a tune you might see 200?
