d16a6 turbo
Old Sep 24, 2011 | 11:55 AM
ant94eh3's Avatar
Icon2 d16a6 turbo
if i bolt on a turbo kit to my d16z6 all stock what would be the safest psi to boost that wont blow my engine?? or should i just build it b4 the turbo??
Old Sep 24, 2011 | 12:22 PM
grumblemarc's Avatar
The Grumpiest
Default Re: d16a6 turbo
Zero PSI. You obviously have no clue what you're doing. You have to set the HP goal first!!! Second you pick the TURBO!!! Why are you noobs always stuck on PSI?!!! PSI don't mean SQUAT until you've picked a turbo. And installing the parts is the EASY part. Now you have to worry about engine management, tuning, slipping clutches, crankcase pressure, blown headgaskets, headlift, monitoring, etc.
Do some research. This aint it.
Old Sep 26, 2011 | 01:23 PM
Julio@Bisimoto's Avatar
LOL, well everyone needs to start somewhere. He is correct though it does take much more than just bolting on a turbo kit.
The most important part of any project/build would be engine management and tuning. With this a good factory stock motor can handle a low hp turbo setup with the correct parts. I recommend investing on quality parts the fist time because it will save you money in the end.
As well take into consideration if you are going to make more HP you will have other items other than just the motor that will need attention to. For example clutch setup, fuel system upgrades, suspension/motor mount upgrades and so on. Do a little research and you will be fine
Old Sep 27, 2011 | 07:20 AM
The Grumpiest
When I started I read for a whole year before I bought my first component. I'm still reading and I've only got what I'd call an "entry level" system. The questions have already been asked and answered if you aren't too lazy to search them out.
Old Sep 27, 2011 | 11:33 AM
ant94eh3's Avatar
well i haven't bought anything yet..i had a full greddy set up but i sold it b4 i could even use it..thanks for the input ill keep that all in mind when the time comes oh an i ment to put d16z6 not a6 i was thinking about my old ef i use to have haha
Old Sep 27, 2011 | 12:03 PM
The Grumpiest
If I were you I'd scour the Marketplace for a used kit/parts. Then find a tuner and ask him what he recommends as far as engine management.
Westrock2000
Nov 27, 2006 03:02 PM
91(si)hatchey
Nov 7, 2006 08:15 AM
97RSTEG
Jul 14, 2006 09:45 AM
