if i have FMU do i still need fuel pressure regulaotr??
Old Apr 17, 2002 | 12:49 PM
turbogsr13z's Avatar
Default if i have FMU do i still need fuel pressure regulaotr??
Old Apr 17, 2002 | 01:04 PM
Sonny's Avatar
25 Year Member
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (turbogsr13z)
It depends. Most FMU's will not control fuel pressure between idle and vacuum. The stock FPR's job is to ramp the fuel pressure up by ~10 psi between idle (20" of vacuum) and atmospheric pressure (0 psi/0").
FMU's like the JR FMU do not start increasing fuel pressure until they hit 0"/0psi. So, your fuel pressure will not rise under vacuum...not what you want.
Some FMU's like the Cartech can control fuel pressure under vacuum to a very small extent. I believe the Vortech SFMU can do it all.
The best FMU is no FMU at all ...
Sonny
[Modified by Sonnyballs, 10:05 PM 4/17/2002]
Old Apr 17, 2002 | 01:09 PM
Cramerox's Avatar
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (Sonnyballs)
hey sonny-
can u elaborate on this? Im going with an vortech fmu but if you got another sugestion
Old Apr 17, 2002 | 01:33 PM
mercury's Avatar
New User
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (Cramerox)
Hondata + injectors
Old Apr 17, 2002 | 04:16 PM
intekragsr's Avatar
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (mercury)
Hondata + injectors
Hondata+Injectors+FPR
Correct? That is what im doing
Old Apr 17, 2002 | 04:57 PM
csufweed's Avatar
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (intekragsr)
no FPR... just Hondata and Injectors and Fuel Pump
Old Apr 17, 2002 | 05:03 PM
intekragsr's Avatar
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (csufweed)
OMG wtf.......first I was told by people on the board the same thing. Hondata, injecotrs and intank fuel pump. Then I was told by importparts that all i need is 440's with hondata and the aem fpr. Now I am hearing opposite.
By the way, im putting on another drag 3 kit.
Someone clear this up for me please before I go crazy.
Old Apr 17, 2002 | 05:18 PM
Smashback's Avatar
Yes, the AEM FPR is fine, it's not an FMU. You are supposed to raise fuel pressure with Hondata if I am not mistaken...Dustin probably knows the specifix!
Old Apr 17, 2002 | 05:36 PM
dustin's Avatar
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (mplex2000)
Your car comes stock with an FPR that raises fuel pressure under boost. That's all you need an FPR for. If your stock one has no trouble maintaining stock idle fuel pressure with a high flow fuel pump, then you don't need another.
Old Apr 17, 2002 | 09:33 PM
SIK IN DA HED's Avatar
New User
Default Re: if i have FMU do i still need fuel pressure regulaotr?? (dustin)
i know... some people were sayin to buy an additional fpr like AEM. i was wonderin "for whut?". i figured you didnt need one.. Hondata, injectors, and highflow intank fuel pump should be sufficient enough. at least dustin cleared it up.
Old Apr 17, 2002 | 09:39 PM
Smashback's Avatar
I thought I say somewhere that with Hondata they wanted to to run 440CC injectors at list 60 PSI base pressure? Maybe I've just had too much crack though?
Go Fast Civic
Dec 1, 2004 01:08 PM
scartail
Oct 12, 2004 11:53 AM
dohc-nyne
Jul 27, 2003 05:50 PM
Familycarfromhell
Feb 9, 2003 07:40 PM
evil_elmo
Oct 13, 2002 02:15 AM
