tach hook-up but no wire from distributor
Old Jun 22, 2006 | 06:38 PM
4dooreg-k's Avatar
Default tach hook-up but no wire from distributor
i did a swap with a jdm b16 (obd2a) into a 00 civic (obd2b) and when i hooked up the distributor there was no wire on the distributor side of the plug for the engine speed output (tach wire). now the tach does not work. just wondering what wire from the ecu do i hook the tach up to? from the posts iv been reading people have been saying its plug "C" slot "2" ckp-p sensor (blue). is that right?
Old Jun 22, 2006 | 07:12 PM
littleredcivic's Avatar
make it easy on yourself. there is a plug at the drivers side firewall that is all by itself with some blue tape and a black plug on it. use a meter and verify the signal. the dist still has an AC wire for tach signal.
Old Jun 22, 2006 | 07:21 PM
4dooreg-k's Avatar
Default Re: (littleredcivic)
ok ill check it out
Old Jun 22, 2006 | 07:27 PM
A.E Motoring's Avatar
Default Re: (4dooreg-k)
tach wire is on the distrib, big fat blue one by its self, but there is also one on the driver side, blue wire on the harness
Old Jun 23, 2006 | 05:28 AM
EE_Chris's Avatar
Default Re: (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">tach wire is on the distrib, big fat blue one by its self</TD></TR></TABLE>
No, it's not.
Old Jun 23, 2006 | 09:34 AM
Vtec4me's Avatar
you dont have to do all that. i have a '00 and all you do is take out the gauge cluster and splice one of the wires that clips into your stock tach. ( not sure what color)
Old Jun 23, 2006 | 09:36 AM
it sounds like the original poster already had the signal wire in the engine bay...might as well just shorten it and connect to the check connector.
Old Jun 23, 2006 | 11:24 AM
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">
No, it's not.</TD></TR></TABLE>
thats how i have mine done, its the only solid blue wire on the distrib harness, unless it matters by obd, then it prolly doesnt, but yea, u dont have to do it like that, there are other ways, mine was just like that cause thats how i got the car
Old Jun 23, 2006 | 11:59 AM
4dooreg-k's Avatar
i checked the connecter by the firewall and i got no signal. now what?
Old Jun 23, 2006 | 12:18 PM
how i have mine, from distrib, the red wire is just regular wire dont mind it, its the blue wire that has the signal
Old Jun 23, 2006 | 12:24 PM
Otherguy's Avatar
NASIOC.com
I know there is a wire behind the cluster, thats where i did mine
Old Jun 23, 2006 | 12:50 PM
EE_Chris's Avatar
Not all Civic's have them. 99-00 to be exact, which his happens to be.
epingquian
Mar 29, 2018 08:29 AM
Tyson
40
Jun 4, 2009 04:24 PM
97grnrs
Jan 11, 2006 07:32 PM
Dropped90Integra
Jan 13, 2005 08:57 PM
YellowCRXSi
Jul 12, 2004 09:55 PM
