Installed new motor, car wont start....
Old Jun 22, 2006 | 08:45 AM
Rbehne2's Avatar
Default Installed new motor, car wont start....
hey guys.
I have a 99 civic dx auto trans. i spun a bearing last month(please dont ask), anyways, I've just put the new motor in with the tranny, distributor, and intake + exhaust manis from the old motor.
now- when I go to start the car the starter will spin, but no spark from the dissy-??
Also, the speedo goes up and down when starting-??
any help on my situation will be greatly appreciated.
thanx
Old Jun 22, 2006 | 10:12 AM
delus1on's Avatar
Default Re: Installed new motor, car wont start.... (Rbehne2)
make sure that all grounds are secured tightly. it sounds funny but sometimes a ground wire may cause this. There should be 2 or three ground to check. Also make sure that your plugs are pluged in tightly
Old Jun 22, 2006 | 11:00 AM
Rbehne2's Avatar
Default Re: Installed new motor, car wont start.... (delus1on)
all grounds are secure. even the fan ground. all plugs clicked(secure). no blown fuses.
I still cant figure out why it wont spark- the dissy im using came off my other motor, so I know it works.
thanx for the reply
anyone else have any ideas???
Old Jun 22, 2006 | 11:35 AM
Rbehne2's Avatar
bump for help
Old Jun 22, 2006 | 12:02 PM
the jdmchop's Avatar
are you getting power to the dizzy?
Old Jun 22, 2006 | 12:31 PM
Rbehne2's Avatar
Default Re: Installed new motor, car wont start.... (anti-lag aka JDMCHOP)
im gonna test it. also, when i put the key in, there is a buzzing sound from the ecu- not a beeping sound.
Old Jun 22, 2006 | 12:35 PM
main relay good?
Old Jun 22, 2006 | 01:20 PM
Rbehne2's Avatar
yea. one other thing was I unscrewed the line from the fuel rail, and no fuel is coming out- i did a second check because i didnt hear the fuel pump come on.
Old Jun 22, 2006 | 01:26 PM
does the pump got power?ground?
did you check for power to the dizzy?
Old Jun 22, 2006 | 02:21 PM
Slopoke's Avatar
When you turn the key on, the fuel pump should prime for a few seconds. Can you hear that?
If not, you probably either have a bad main relay or you forgot to put the ground on the thermostat housing(I've seen that happen alot).
Old Jun 22, 2006 | 02:22 PM
Slamaccord's Avatar
Sounds ECU related to me. No fuel or sparks usually goes back to the ECU.
Old Jun 23, 2006 | 11:33 AM
Rbehne2's Avatar
Default Re: Installed new motor, car wont start.... (Slamaccord)
OK, it started this morning and ran for a minute or so, then it started pausing so i shut it down. Also, the buzzing sound stopped for a while.
I used the same ecu, and the buzzing is coming from the main relay, but I replaced it with two different used ones and its still buzzing...??
then again it wont start, and the buzz wont stop.??
any other ideas?
Old Jun 23, 2006 | 01:06 PM
hatchi's Avatar
check all your fuses. timing order
Old Jun 23, 2006 | 01:09 PM
Rbehne2's Avatar
Default Re: Installed new motor, car wont start.... (hatchi)
all fuses are good timing order is good- it was in the same order on my other motor. still cant figure it out...
Old Jun 23, 2006 | 02:42 PM
viahiptop's Avatar
recheck all the grounds on your engine harness
Old Jun 24, 2006 | 11:29 PM
Rbehne2's Avatar
OK....
So it was a bad ground..
The plastic piece that is mounted behind the block has a nut that was kinda rusty, so i cleaned the contacts and it started right up!!
Another thing is, now i have a check engine light, and when I go to get it scanned tomorrow ill know of any other potential problems.
I'll fill you guys in, just incase anyone else has a problem similar to this.
Old Jun 24, 2006 | 11:49 PM
Wicked-Civic's Avatar
I had some what the same problem in a friends car. And it was the same problem the nut on the back had build up on it and we cleaned it. And it runs great now. I wish i would have seen this post earlier. It would have saved you alot of trouble. But the point is you got it running. Congrats man
Old Jun 25, 2006 | 02:16 PM
Rbehne2's Avatar
I got he car scanned today for the engine light- P0505 IDLE CONTROL SYSTEM MALFUNCTION.
the motor runs pretty good- this is the first install i have ever done by myself.
now i wish i would have taken pics- but nothings aftermarket, so....
what was interesting was, the new motor was a five speed motor, so i ended up taking off the clutch and flywheel(which is only about a month old(so i was told)) and installing my tq converter. -if anyone wants to pick up this clutch, Im in md-$15 bucks and its yours.
Thanx again guys for all the help
dkillahster
Sep 10, 2010 12:26 PM
Banner
16
Aug 12, 2010 12:19 PM
mike93
Dec 5, 2005 11:02 AM
CReXB18
14
Jun 16, 2004 05:02 AM
dfoxengr
Jan 15, 2003 06:26 PM
