please please, car wont start.
Old Jan 9, 2003 | 05:07 PM
dfoxengr's Avatar
Default please please, car wont start.
b18b1 motor. i just changed the distributor, and car was running before the change..although i hadnt driven or started it in about a week and in the week it got cold here. so i change it and try to start the car and its like this spinning sound...i figured out the camshaft makes the rotor spin but it doesnt start? so i try to start it for awile and it backfires a few times...awile later it wont even spin and i take ut my spark plugs and they are wet with fuel...so i leve them out for a few days to let it evaporate and try again...no luck. i got new plugs today and tried it and it sounds better and fires a few times (not all cylinders fire at a time) and it still wont workk, please help tech guys..?
Old Jan 9, 2003 | 05:45 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (hybridvteceg)
bump
Old Jan 9, 2003 | 07:11 PM
Turbo Powa's Avatar
check you connections again and spark plug wires.....
Old Jan 10, 2003 | 02:32 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (Panda EK)
i did that but think its crucially flooded?
Old Jan 11, 2003 | 02:00 PM
dfoxengr's Avatar
upsss
Old Jan 11, 2003 | 09:29 PM
dfoxengr's Avatar
bump
Old Jan 11, 2003 | 09:35 PM
tominos's Avatar
put the old distributor back in and see if it runs. the new one you got is probably defective.
Old Jan 11, 2003 | 09:47 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (tominos)
yeah i tried that too and is still doesnt work, i knoiw the new dist is fine, i checked the sparks from each wire but is it possible that an engine could be flooded so badly that it wont start even after like 30 mins of trying to start it?
Old Jan 11, 2003 | 09:51 PM
tominos's Avatar
yea if you flooded it, it probably won't start b/c too much fuel. i forgot how to fix it though.
Old Jan 11, 2003 | 10:03 PM
fcardoso's Avatar
Could be a few things! First either you put the wires in the wrong order, and second, the Dist timing is way out. The first thing could cause your car to backfire.
Check those out properly first. It must be either one!!
Old Jan 11, 2003 | 10:09 PM
USCdrifter's Avatar
not 100% sure...but try this...reclock the distributor...turn the distributor internal thing 180 degrees...this same thing happened to me...my friend turned it and car fired right up...
Old Jan 11, 2003 | 10:11 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (RHtracer)
i have tried all of these suggestions..
Old Jan 11, 2003 | 10:33 PM
Cnote's Avatar
this happened to me once where i changed the dist and my cam timing was thrown off by almost 2 teeth.
check your timing also
Old Jan 11, 2003 | 10:37 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (Cnote)
odd. only the ignition timing should be messed up...but ive tried every degree and it wont work
Old Jan 12, 2003 | 11:07 AM
PnX-R's Avatar
I agree with the other dudes.. I'd double check and make sure that the wires are put on correctly.. Last time I helped my dad fix his teg and assured me that the wires were on right on the distributor.. I double checked it an hour later and that was the problem.. The engine did the same things you said.. It would almost start and then die..
But anyways, good luck with whatever you do..
Old Jan 12, 2003 | 01:16 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (PnX-R)
hmm, anyone know the proper order so i can recheck. if looking from the pasenger side start from the bar thing in the middle that goes straight up and go left of that, then below, then right, then up....and put the order here.
Old Jan 15, 2003 | 08:55 AM
dfoxengr's Avatar
?please,lol
Old Jan 15, 2003 | 02:55 PM
project_mercy's Avatar
I don't know on a teg, but on my civic, if you're looking a the cap with the square/flat side up, on the bottom left is cylinder one. It has a little "C" in a circle next to it marking it as the first cylinder. In a clockwise fashion, the next is 3, then 4, then 2.
Old Jan 15, 2003 | 03:10 PM
Quiz's Avatar
Default Re: please please, car wont start. (project_mercy)
Did you take the distributor completely off the head? If so you may have put the distributor on a 180deg out. Set the motor for TDC, pull the cap off make sure it's on wire #1 and not 4. Helms manual details the cylinder referance. Are you sure you have spark seen problems with the ignitor pack in the coil of those integras before.
Old Jan 15, 2003 | 06:26 PM
dfoxengr's Avatar
Default Re: please please, car wont start. (Quiz)
yeah i have spark, shocked the **** out of myself thought i was only touching rubber, lol. and i checked the pattern against my friends teg and we did the same? main problem is it backfires then refuses to even crank after awhile...
bauergold
Jul 28, 2017 05:15 PM
avargas28
Apr 15, 2009 05:32 PM
bmxbikes
22
Jul 4, 2007 07:23 PM
chinese buffet
Jul 16, 2006 05:09 AM
hybridEj6
Jun 25, 2003 10:57 PM
