waterpump???
Old Jun 21, 2006 | 09:07 PM
cr-rex88's Avatar
Default waterpump???
ok heres the deal iv got a 91 hatch Si with a single cam ZC thats been over heating alot lately so i got a new radiator, hose's and thermostat...well it doesnt over heat anymore but now it will start to get really warm but when i rev to about 4000... it goes right back down so do i need a waterpump or what? cuz thats the only thing left oh and yeah the fan switch does work so i know its not that...any help would be great......
Old Jun 21, 2006 | 10:17 PM
philkehn's Avatar
usually when the waterpump goes you will have the pinhole leaking? do you have any leaks?
Old Jun 23, 2006 | 09:10 PM
cr-rex88's Avatar
Default Re: (philkehn)
come to thin about it now yeah i do....so is that why when i rev the temp goes back down then?
Old Jun 23, 2006 | 09:12 PM
RCautoworks's Avatar
Default Re: (cr-rex88)
Well where is the leak around ?
It sounds like you could have a clogged system, whens the last time you did a flush ?
Old Jun 23, 2006 | 09:27 PM
cr-rex88's Avatar
Default Re: (90blackcrx)
i cant really see where its coming from somewhere arould the bottom of the block, but yeah i flushed it last week and i work at goodyear so i used all the hightech bullshit machines to do it.
Old Jun 23, 2006 | 09:38 PM
Take the timing cover off and inspect there, also it could be a stuck thermostat.
Old Jun 24, 2006 | 06:58 AM
uberhaulin's Avatar
he said he has a new thermostat..... that shouldnt be stuck
Old Jun 24, 2006 | 03:28 PM
Default Re: (uberhaulin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uberhaulin &raquo;</TD></TR><TR><TD CLASS="quote">he said he has a new thermostat..... that shouldnt be stuck</TD></TR></TABLE>
I have seen brand new ones get stuck, and I also have seen people install them backwards.
Old Jun 27, 2006 | 04:06 PM
cr-rex88's Avatar
lol i work at goodyear so no i didnt install it backwards but yeah iv seen that happen also.
Old Jun 27, 2006 | 05:12 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Have you pressure tested it?
If it has a leak that is an easy way to find it..
How about the raditor cap? It has to hold pressure also..
Old Jun 27, 2006 | 05:16 PM
Speed--Freak's Avatar
It's getting warm because your coolant flow has been reduced either by a clog or the pump is cavitating.
All I know is if your water pump locks, it will take your timing belt with it. THen you get to buy a new head.
Burningrambo
16
Nov 27, 2013 08:07 AM
89Jayda206
May 26, 2013 12:26 AM
accord2civic2prelude
Dec 15, 2009 03:36 PM
drjondurst
11
Mar 31, 2003 05:33 PM
pelotudo
May 30, 2002 07:13 PM
