Civic axle ?
Old Jun 21, 2006 | 05:03 PM
Awsom-o 4000's Avatar
Default Civic axle ?
I know a guy who says his right side axle "clicks" somtimes. He already has a new one to replace it. What COULD this problem be, and how much Could it be to have the work done? Thanks (97 civic)
Old Jun 21, 2006 | 05:13 PM
EG2Driver's Avatar
Default Re: Civic axle ? (Sofa_King)
the problem is that his CV bearings ran out of lube (grease) and are clicking because of that. Replace the axle and your done. There is a DIY on HT, just do a search.
Old Jun 21, 2006 | 05:18 PM
Default Re: Civic axle ? (DeadEnd9009)
Thanks man^^^
Old Jun 21, 2006 | 05:22 PM
EG2Driver's Avatar
yea its not htat hard of a job. Just make sure to have some new fluid to put in the motor. I suggest using Honda MTF, but many people use other oils. DO NOT use motor oil, get tranny oil.
Old Jun 21, 2006 | 05:26 PM
Otherguy's Avatar
NASIOC.com
I have had no problems with motor oil
Old Jun 21, 2006 | 05:46 PM
EG2Driver's Avatar
Default Re: Civic axle ? (Otherguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Otherguy &raquo;</TD></TR><TR><TD CLASS="quote">I have had no problems with motor oil </TD></TR></TABLE>
on the long run you will. Its too thin, it runs too much so it doesnt lube right. Gear oil is like 75W90. There is a reason its called motor oil and not transmission fluid.
Old Jun 21, 2006 | 06:13 PM
delslowhonda's Avatar
yeah i just tackled the axle swap guide myself. it turned out to be very easy indeed, and i'd kick myself in the nutz to pay somebody to do it and charge 140bux. viva la honda tech for all the great how to guides.
Old Jun 21, 2006 | 06:19 PM
Default Re: Civic axle ? (delslowhonda)
Very helpful^^^
Old Jun 21, 2006 | 07:17 PM
EG2Driver's Avatar
Sofa_King. Get everything OEM and you'll never have to worry.
Old Jun 21, 2006 | 07:52 PM
sniggler316's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">
on the long run you will. Its too thin, it runs too much so it doesnt lube right. Gear oil is like 75W90. There is a reason its called motor oil and not transmission fluid. </TD></TR></TABLE>
Honda says to just use motor oil...
Old Jun 21, 2006 | 08:44 PM
Default Re: Civic axle ? (sniggler316)
Thanks guys
Old Jun 21, 2006 | 08:50 PM
fmrprojects's Avatar
its easy and use either honda mtf or 10w-30 motor oil
Old Jun 23, 2006 | 04:40 PM
Otherguy's Avatar
NASIOC.com
Default Re: Civic axle ? (fmrprojects)
MOTOR OIL WORK DAMNIT!!! lol... nuff said
peekeesh
18
May 1, 2010 01:21 PM
aziaticvang
Jan 8, 2008 04:50 PM
Reborn
Acura TL, RL & ZDX
Sep 18, 2007 05:29 PM
Hyjnx
11
Feb 13, 2007 04:14 AM
kihun_cha
Jan 20, 2006 10:36 PM
