d16z6 questions
Old Jun 21, 2006 | 03:27 PM
WorrGame13's Avatar
Default d16z6 questions
I've got a 91 CRX that I'm putting a d16z6 from a 96 Civic in. I had one for a 95 Civic in it go bad on me. I've got the p28 ecu from the 95 motor already in the car and everything else for that matter(including motor). My question is would it be possible to convert the 96 motor to work with the p28 ecu/wire harness? Or do I need to figure something else out?
Old Jun 21, 2006 | 03:44 PM
lsvtecSIrex's Avatar
well a 96 civic ex should have a d16y8 not z6. the y8 is obd2. i think u can just use the old wiring harness and change out little stuff to keep it obd1 right? like injectors, dizzy, and alternator
Old Jun 27, 2006 | 03:07 PM
WorrGame13's Avatar
Default Re: (lsvtecSIrex)
Yes, it is a d16y8. I heard that changing the injectors and some other things will allow me to keep it obd1, but I don't know what exactly.
Another question I have is will the transmission and stuff I have from my z6 still bolt to the y8 easy enough? Also, will the y8 fit the motor mounts from the z6 without modifications?
Old Jun 27, 2006 | 03:10 PM
d16vtecx's Avatar
Default Re: (WorrGame13)
trans will work
mounts are the same
Old Jun 27, 2006 | 03:39 PM
WorrGame13's Avatar
Default Re: (d16vtecx)
I've got a 6 puck race clutch and a light-weight flywheel from the d16z6, will those fit the d16y8 motor?
roblong1962
Oct 16, 2017 06:14 PM
ilovesd90macs
Jan 26, 2011 07:35 PM
WeirdRich
22
Jun 7, 2007 05:30 AM
95civicSirCoupe
10
May 28, 2004 08:53 AM
