Gauge Cluster Quesion!!!!!!!!!!!!!!!!!
Old Jun 21, 2006 | 05:14 AM
KimChiKid's Avatar
Default Gauge Cluster Quesion!!!!!!!!!!!!!!!!!
Hey guys I had a 1999 Civic DX gauge cluster for my hatch and I am switching it out for a EX cluster the only difference is the green pin I think for the gas meter does not fit into the ex cluster it is also in a different spot.....Just wondering how to tackle this situation thanks!!!!!!!!!!!!!!!!!
I need help ASAP working on it now!
Old Jun 21, 2006 | 05:47 AM
KimChiKid's Avatar
Default Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (KimChiKid)
anyone?
I did a search and came up with nothing....
Old Jun 21, 2006 | 05:53 AM
J98EX's Avatar
I put an EX cluster in my 98 CX hatch and everything plugged right in and worked fine...
Old Jun 21, 2006 | 06:02 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (J98CX)
So your existing gauge cluster harness doesn't plug n play with your new cluster?
You may need to find the correct harness for the new cluster.
Old Jun 21, 2006 | 07:44 AM
littleredcivic's Avatar
i have never seen a 96-00 cluster that didn't plug and play yet...even an acura EL cluster plugs right in.
Old Jun 21, 2006 | 07:46 AM
SkoundrelUSA's Avatar
cute little bastard
are you sure its from a 96-00 Ex?
Old Jun 21, 2006 | 09:43 AM
KimChiKid's Avatar
Default Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (SkoundrelUSA)
Yes, I will take pics of it in a minuite to show you want I am tlaking about
Old Jun 21, 2006 | 09:47 AM
gabebauman's Avatar
There should be no reason it would not fit...as long as both clusters are from a 96-00 model civic.
Old Jun 21, 2006 | 09:57 AM
EFstyle's Avatar
i also have a 99 dx hatch and was wonderign what you do with the tach?
Old Jun 21, 2006 | 10:04 AM
KimChiKid's Avatar
Default Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (gabebauman)
What is the small green plug for?
Picture here:
does this even need to be plugged in?
Here is the picture of the cluster:
here is the back side of the cluster. Everything that is circled fits except the small green plug which I assume is for the plug above but doesn't fit:
Please help!
Old Jun 21, 2006 | 10:05 AM
KimChiKid's Avatar
Do I need that green plug I guess is my real question....
Old Jun 21, 2006 | 10:10 AM
KimChiKid's Avatar
Old Jun 21, 2006 | 10:11 AM
KimChiKid's Avatar
I guess I could always custom wire the plug but buy a new plug that will fit the tachometer....*ugh* lol!
Old Jun 21, 2006 | 10:14 AM
Ilovemyemone3's Avatar
lol BUMP GET HIM AN ANSWER. cuz i got no clue...
Old Jun 21, 2006 | 10:15 AM
cute little bastard
Default Re: (KimChiKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid &raquo;</TD></TR><TR><TD CLASS="quote">Do I need that green plug I guess is my real question....</TD></TR></TABLE>
I'm not sure but I think it might just control one of the lights or cruise control or something.
Just leave it off and see if everything is ok
Old Jun 21, 2006 | 10:17 AM
KimChiKid's Avatar
Default Re: (SkoundrelUSA)
That is what I will ultimately have to do I just wanted to see if anyone just had a direct answer thanks!
Old Jun 21, 2006 | 10:22 AM
lv6l's Avatar
my friend's eg has a green one like that. he plug it into the yellow one. it's for his shifting light. some model civic from canada will have shifting lights. so when you bought the new cluster it was probably from the US and your car is from canada or someone might of put it in. try putting it in the yellow and see if everything works. ifs its not for shifting lights its for SRS. the big plugs are for gas/temp/speedo/rpm. good luck.
i dont think its needed. just try running it without pluging it in and see if everything works.
Old Jun 21, 2006 | 10:31 AM
KimChiKid's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">my friend's eg has a green one like that. he plug it into the yellow one. it's for his shifting light. some model civic from canada will have shifting lights. so when you bought the new cluster it was probably from the US and your car is from canada or someone might of put it in. try putting it in the yellow and see if everything works. ifs its not for shifting lights its for SRS. the big plugs are for gas/temp/speedo/rpm. good luck.
Thanks!
Old Jun 21, 2006 | 12:17 PM
DohcSide's Avatar
bump for picks of the results
Old Jun 21, 2006 | 01:06 PM
EeeJayEight's Avatar
Default Re: (DohcSide)
i think that green plug is for abs? i know the yellow is for srs.. but i am not sure.. i know i disconnected a plug like that so my ABS light when off... stupid EM1 rear discs...
Old Jun 21, 2006 | 06:18 PM
EFstyle's Avatar
Default Re: (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight &raquo;</TD></TR><TR><TD CLASS="quote">i think that green plug is for abs? i know the yellow is for srs.. but i am not sure.. i know i disconnected a plug like that so my ABS light when off... stupid EM1 rear discs...</TD></TR></TABLE>
i was told the orange one that isnt used but is taped up behind the cluster is for abs...
Old Jun 22, 2006 | 08:24 PM
Default Re: (EKEJ6)
yea... i was looking at my cluster today.. i retract my ABS statement
Old Jun 22, 2006 | 08:38 PM
Kaji's Avatar
It's definately not needed for your basic read outs like speed, tach, temp, fuel, and the indicator lights. I have a 96 cx and I don't have a green plug so I'm guessing it's for an option addition that didn't come on my base model. i.e. it's not necessary for normal driving purposes.
Old Jun 22, 2006 | 09:20 PM
johnny_tdi's Avatar
Default Re: (Kaji)
The green plug is for abs. My abs light was on and after I unplugged the green harness it went off
GSRBrent
Nov 30, 2007 07:09 PM
GOLDBERG
May 23, 2004 06:52 PM
chinkyEyez
11
May 21, 2004 01:51 PM
junglerunna
Nov 27, 2002 08:31 PM
