Gauge Cluster Quesion!!!!!!!!!!!!!!!!!
Hey guys I had a 1999 Civic DX gauge cluster for my hatch and I am switching it out for a EX cluster the only difference is the green pin I think for the gas meter does not fit into the ex cluster it is also in a different spot.....Just wondering how to tackle this situation thanks!!!!!!!!!!!!!!!!!
I need help ASAP working on it now!
Vice President/CEO
Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (J98CX)
So your existing gauge cluster harness doesn't plug n play with your new cluster?
You may need to find the correct harness for the new cluster.
Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (gabebauman)
What is the small green plug for?
Picture here:
does this even need to be plugged in?
Here is the picture of the cluster:
here is the back side of the cluster. Everything that is circled fits except the small green plug which I assume is for the plug above but doesn't fit:
Please help!
Picture here:
Please help!
Re: Gauge Cluster Quesion!!!!!!!!!!!!!!!!! (KimChiKid)
I guess I could always custom wire the plug but buy a new plug that will fit the tachometer....*ugh* lol!
cute little bastard
Re: (KimChiKid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KimChiKid »</TD></TR><TR><TD CLASS="quote">Do I need that green plug I guess is my real question....</TD></TR></TABLE>
I'm not sure but I think it might just control one of the lights or cruise control or something.
Just leave it off and see if everything is ok
my friend's eg has a green one like that. he plug it into the yellow one. it's for his shifting light. some model civic from canada will have shifting lights. so when you bought the new cluster it was probably from the US and your car is from canada or someone might of put it in. try putting it in the yellow and see if everything works. ifs its not for shifting lights its for SRS. the big plugs are for gas/temp/speedo/rpm. good luck.
i dont think its needed. just try running it without pluging it in and see if everything works.
Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l »</TD></TR><TR><TD CLASS="quote">my friend's eg has a green one like that. he plug it into the yellow one. it's for his shifting light. some model civic from canada will have shifting lights. so when you bought the new cluster it was probably from the US and your car is from canada or someone might of put it in. try putting it in the yellow and see if everything works. ifs its not for shifting lights its for SRS. the big plugs are for gas/temp/speedo/rpm. good luck.
Thanks!
Thanks!
Re: (DohcSide)
i think that green plug is for abs? i know the yellow is for srs.. but i am not sure.. i know i disconnected a plug like that so my ABS light when off... stupid EM1 rear discs...
Re: (EeeJayEight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight »</TD></TR><TR><TD CLASS="quote">i think that green plug is for abs? i know the yellow is for srs.. but i am not sure.. i know i disconnected a plug like that so my ABS light when off... stupid EM1 rear discs...</TD></TR></TABLE>
i was told the orange one that isnt used but is taped up behind the cluster is for abs...
It's definately not needed for your basic read outs like speed, tach, temp, fuel, and the indicator lights. I have a 96 cx and I don't have a green plug so I'm guessing it's for an option addition that didn't come on my base model. i.e. it's not necessary for normal driving purposes.
GOLDBERG
05-23-2004 06:52 PM
chinkyEyez
11
05-21-2004 01:51 PM
