Help spark problem need pics of dizzy plug and ecu slots
ok so here is my story my car has no spark but does have fuel....
it all started when i painted my dizzy cap and was about to paint my fuel rail... after i paint the cap and begin to take the fuel feed off the rail i drop that dumb washer and i rolled into the abyss cause i cannot find it ANYWHERE...while i was tring to fix it i spit fuel all over my engine bay but besides the point i rigg it for now with some tin foil to where it doesn't leak for now.... i get my car started and it runs fine till it just stops for no apparent reason... i change my ignitor...try my old dizzy that i know for a fact worked and it doesn't...
so now im about to just about to rewire my dizzy plugs right to the ecu but i need pics of what wire goes to what plug
i have no idea what else to check....ive checked every single fuse and can it be the main relay? i have fuel tho....
the dizzy on it now is brand new from Distributor king and my CEL is a code 15...ignition output signal
Modified by Sohc 4door Rye at 10:25 PM 6/20/2006
mugenhatch92
17
Jun 26, 2005 05:53 PM
blackeg
39
Mar 10, 2004 07:17 AM
Tij
Sep 2, 2002 04:49 PM
