99 si keeps breaking ECU's
Old Jun 20, 2006 | 05:52 PM
jnpapmech's Avatar
Default 99 si keeps breaking ECU's
Does anybody know what the hell is going on with my 99 si , I've broken three,yea that's right three ECU's in the past nine months.The car will be running fine,then all of the sudden it spits and sputters then nothing.I just put a p06 ecu in it.It works good so far,but idles eractly up and down. Is it a short?Map sensor?Main relay?PLEASE SOMEBODY HELP!!!
Old Jun 20, 2006 | 06:11 PM
JDM B16A's Avatar
Default Re: 99 si keeps breaking ECU's (jnpapmech)
Regarding the eractly up and down idle is because of the P06. I know because I haD the same problem with that ECU and I swapped in a P2T and now its idle'n perfectly.
Old Jun 20, 2006 | 07:36 PM
gold_ef's Avatar
distributor can destroy them
Old Jun 20, 2006 | 07:54 PM
hi-Powered's Avatar
injectors can destroy them too..
are you getting any cel?
Old Jun 21, 2006 | 05:28 PM
jnpapmech's Avatar
Default Re: (hi-Powered)
cel?
Old Jun 21, 2006 | 05:33 PM
Otherguy's Avatar
NASIOC.com
Default Re: (jnpapmech)
check engine light... are you using the RIGHT ecu?
Old Jun 21, 2006 | 07:01 PM
E46Kid's Avatar
Default Re: (gold_ef)
try putting the original ecu p2t
Old Jun 21, 2006 | 07:30 PM
FalkenSiR's Avatar
Default Re: (EkSi)
OBD1 P06 made for a 1.5 sohc non vtec running an OBD2 B16?
Stay away from fixing up cars for the rest of your existance.
Old Jun 22, 2006 | 04:33 PM
JDM B16A's Avatar
Default Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 P06 made for a 1.5 sohc non vtec running an OBD2 B16?
Stay away from fixing up cars for the rest of your existance.</TD></TR></TABLE>
P06 can be program to run B16 mind you.
Old Jun 22, 2006 | 04:37 PM
Archidictus's Avatar
Unceasing Measure
Why aren't you running a stock ECU?
Old Jun 22, 2006 | 05:47 PM
ultimatehonda's Avatar
Is the Po6 chipped or is it stock? If its stock it probably will not run right since the 99 si is a dohc vtec motor. If it is chipped, what type of program are you running?
Old Jun 22, 2006 | 08:21 PM
Kenshou Motorsports's Avatar
Stay away from fixing up cars for the rest of your existance.</TD></TR></TABLE> true, true
ennohohbee
Mar 13, 2010 02:57 PM
davemcd321
Oct 22, 2007 08:22 AM
iRIDEdumped
32
Apr 25, 2005 06:34 PM
IWearMyKswiss
Oct 22, 2003 10:51 PM
SLeePeR012
May 15, 2003 09:17 AM
