compression specs for a 92 LS
hey, i was wondering if anyone knew what all four cylinders on a 92 LS (B18A1) are supposed to read.
i'm going to run a compression test tommorow and i'd like to see how close to OEM spec i am.
thanks
thanks
when I did my compression check about 3-4 months ago, I got about 160-165 all across. im pretty sure a PERFECTLY healthy running LS would pull off 180-190.
*update*
i finally got around to doing the compression test and i read a 195 all the way across. seems pretty high, but it is consistant to all 4 cylinders so i'm guessing the engine is healthy.
thanks for the info guys
