How to make shape of this port?
Old Jun 17, 2006 | 05:53 PM
MidShipCivic's Avatar
Default How to make shape of this port?
This is my Nissan DOHC V8 for my 240 I'm building a Turbo manifold
for it but there oval I'd like to get this shape down in tubing to a nice transition so I can
boost this great V8.
Old Jun 17, 2006 | 06:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: How to make shape of this port? (MidShipCivic)
take a flange and make a cad drawing of it. have someone machine the shape then split it in half, youd just put the tube in there and tighten it down till it made the shape
Old Jun 17, 2006 | 06:28 PM
Default Re: How to make shape of this port? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">take a flange and make a cad drawing of it. have someone machine the shape then split it in half, youd just put the tube in there and tighten it down till it made the shape</TD></TR></TABLE>
Thats what I dont want to do though.
I dont know but cant I just half cut two peices of tubing?
Old Jun 17, 2006 | 06:31 PM
all_motor_mike's Avatar
put some round tubing in a vice and squeeze it, it wont be perfect but it works.
Old Jun 17, 2006 | 06:38 PM
Default Re: How to make shape of this port? (all_motor_mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all_motor_mike &raquo;</TD></TR><TR><TD CLASS="quote">put some round tubing in a vice and squeeze it, it wont be perfect but it works.</TD></TR></TABLE>
I'm sensitive to hurting the flow so early .
Old Jun 17, 2006 | 06:42 PM
wantboost's Avatar
Who is Mr Robot?
you could have some pieces cnc machined that taper from the oval port to round tube
Old Jun 17, 2006 | 06:46 PM
Like this guy... http://www.sdsefi.com/air12.html
Eh this is time consuming.
Old Jun 17, 2006 | 06:50 PM
I think I'll just put them in a vice and crush them carefully.
unless someone has a better idea
Old Jun 17, 2006 | 07:00 PM
k24em2's Avatar
Default Re: (MidShipCivic)
Hydraulic press
Old Jun 17, 2006 | 10:28 PM
JDMorgan's Avatar
Default Re: (k24em2)
v8 silvia?
Old Jun 17, 2006 | 11:14 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (KraZEtEggIE)
yep.
for thinking outside of the box
Old Jun 17, 2006 | 11:26 PM
Lamchop0000's Avatar
i just brewd this up. its a pip cut in half and filled with a wedge piece. the design might not look so efficent but who knows.
Old Jun 17, 2006 | 11:39 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: How to make shape of this port? (Lam.N)
yea, this was my idea.
Old Jun 18, 2006 | 12:06 AM
k24em2's Avatar
Now get that machined out of stainless steel billet.
All eight of them.
Old Jun 18, 2006 | 12:26 AM
DBAl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">
That seems like the best option
btw you should post up picks when you get this project done. I have seen some v8 240s but none that have a turbo. Sounds like its going to be an amazing car.
Old Jun 18, 2006 | 01:40 AM
blueoval557's Avatar
Default Re: How to make shape of this port? (BigAl1911)
Go with the vise method. If your careful, it will turn out fine and wont hurt flow at all. Get it to where it fits into the flange, then from the inside, tap it out until it is tight around the outer edge of the port hole in the flange. Weld it, and be done.
Kyle
Old Jun 18, 2006 | 01:43 AM
weiRtech's Avatar
OG Fabricator
Default Re: How to make shape of this port? (blueoval557)
you want something like this:
i know the champ car series cosworth v8's have manifolds that look similar to this but i'm not sure what method they use for them although i'd love to know!
Old Jun 18, 2006 | 07:48 AM
Yes a Nissan V8 DOHC VH45DE, there special and this thing you can tell has massive potential. Stock Forge rods and crank six bolt mains + girdle, titanium valve springs, OEM coated pistons, variable cam timing, dual stage manifold, oem tubular headers, COP ignition, chain timing belt. its a 93 engine too
It has been done to the 240 before. The 300zx flywheel has the same 8 bolt pattern, also an adaptor plate is now being made for it.
I'm having rods & pistons made stock dimension stock compression + haltech and a journal bearing 4088r.
http://ellisautoworkz.com/cars/450sx/thumbs.php
Old Jun 18, 2006 | 10:36 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: How to make shape of this port? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Now get that machined out of stainless steel billet.
All eight of them.</TD></TR></TABLE>
i could do it on our 5 axis
Old Jun 18, 2006 | 10:42 AM
The port on the head is 28mm tall and 54mm wide I'm really thinking about doing CNC peices.
Old Jun 18, 2006 | 10:46 AM
wantboost's Avatar
Who is Mr Robot?
we could do that no problem if we could get some downtime
Old Jun 18, 2006 | 01:07 PM
JDMorgan's Avatar
i would keep the header tubes the same circumference as the ports.
Old Jun 18, 2006 | 10:06 PM
Rosko's Avatar
I would have the whole flange cnc'd, oval on one side to a round on the other.
Old Jun 18, 2006 | 10:13 PM
Rosko's Avatar
Default Re: (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">The port on the head is 28mm tall and 54mm wide I'm really thinking about doing CNC peices.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">i would keep the header tubes the same circumference as the ports. </TD></TR></TABLE>
I came up with 1.750 ID tubing as the same port circumferance.
Old Jun 19, 2006 | 04:33 PM
LordAphotic's Avatar
wow i didnt know nissan made v8s..... except for the truck ones... but this one doesnt seem half bad... im looking into it im considering it for my kit car now....
i need to find out how much the engine weights though...
