testing compression
Old Jun 17, 2006 | 09:42 AM
SL_RICK83's Avatar
Default testing compression
I have a 93 civic ex botor blown, I bought an engine from a local junkyard out of a 2000 civic si, is there anyway to check the compression of the engine b4 i try and put it in??
Old Jun 17, 2006 | 09:44 AM
dr_latino999's Avatar
Default Re: testing compression (SL_RICK83)
Hmm, I know you can do a leakdown test with a motor out of the chassis...
This is what I would think, someone shoot me if I am wrong -->
If motor is attached to transmission and has a starter, run a battery connection straight to the starter and "jump it" causing the motor to turn over. I have no clue if this would work, but it sounds reasonable in my little brain.
Old Jun 17, 2006 | 09:48 AM
SL_RICK83's Avatar
Default Re: testing compression (dr_latino999)
well I thought about turning the motor over by hand, but then i thought I probably couldnt spin it enough to build any kind of compression. Any thing I should out for, I have no history behind this engine a grandma couldve driven it or some idiot that ran all the oil out of it and drove thge **** outta it.. Im half tempted to just buy some new pistons and rings bearings and gaskets, I took the tranny off of it, it looks good, I am however missing the ECU for the engine that had already been taken from the Junkyard. I think My harness should plug in off the shock towers any thing I should know??
Old Jun 17, 2006 | 09:52 AM
SL_RICK83's Avatar
oh one other thing before i head to the auto part store to get a comp tester, how much compression should a b16 have in each cylinder??
Old Jun 17, 2006 | 09:58 AM
SL_RICK83's Avatar
bump
Old Jun 17, 2006 | 12:49 PM
RCautoworks's Avatar
Engine has to be brought up to operation temperatures to do a compression test. So no
JDM_EK_JOE
Oct 22, 2007 07:11 PM
sirguy01
Jul 6, 2006 09:03 PM
spike
Jun 26, 2004 05:23 PM
S13 slide
Feb 6, 2002 05:50 PM
