head bolts too tight?
Old Jun 16, 2006 | 10:36 AM
motorhead_ls's Avatar
Default head bolts too tight?
hey all i'm new, i'm also trying to remove the head off my 90 Teg GS. motor has about a 100k and the bolts don't seem to budge even when i use a 120psi impact wrench! according to the book, they should only be torqued around 48 lbs. any suggestions?
Old Jun 16, 2006 | 11:23 AM
Nors's Avatar
pb blaster?
Old Jun 16, 2006 | 11:26 AM
mike9571's Avatar
Default Re: (Nors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nors &raquo;</TD></TR><TR><TD CLASS="quote">pb blaster?</TD></TR></TABLE>
soak them in liquid wrench
Old Jun 16, 2006 | 12:07 PM
ferngsr's Avatar
Default Re: head bolts too tight? (motorhead_ls)
ur maybe not turning it the right way try the other way
Old Jun 16, 2006 | 12:37 PM
nitrofish420's Avatar
A nice long breaker bar should do the trick.
Old Jun 16, 2006 | 01:20 PM
thanks. and i am turning them correctly and in the right pattern. the last thing i wanna do is break a bolt off in the block! done it before and it's way too embarassing taking that to the shop to get it out.
Old Jun 16, 2006 | 03:09 PM
ripperbone's Avatar
dont use a impact it will twist the bolts, use a breaker bar
Old Jun 16, 2006 | 03:10 PM
__oversea's Avatar
Default Re: (ripperbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ripperbone &raquo;</TD></TR><TR><TD CLASS="quote">dont use a impact it will twist the bolts, use a breaker bar</TD></TR></TABLE>
then when to use impact gun?
Old Jun 16, 2006 | 03:13 PM
ok, i guess a breaker bar is my last hope. liquid wrench doesn't do squat. so much for factory torque specs!
Old Jun 16, 2006 | 03:29 PM
ripperbone's Avatar
Default Re: (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">
then when to use impact gun?</TD></TR></TABLE>
i dont on head bolts. I use a breaker bar and a pipe to break them loose then use a ratchet
Old Jun 16, 2006 | 05:58 PM
mike9571's Avatar
The best breaker bar to use it your jack handle. You cant get plenty of force with it.
Old Jun 17, 2006 | 05:31 AM
acuramike's Avatar
use PB blast or mystery oil and breaker bar with foot and a half pipe at the end if it doesnt worktake it to shop .
Old Jun 17, 2006 | 06:56 AM
T3k C's Avatar
Breaker bar +1!!!
Old Jun 17, 2006 | 11:05 AM
boostednlinefor's Avatar
I always thought impact guns were easier on fasteners and less likely to break them?
Old Jun 17, 2006 | 11:22 AM
ripperbone's Avatar
impact guns twist the bolts and some times to much that the threads break off in the head.
well today i had to pull my b16 head off, and I used a breaker bar and pipe on the end and had no problems getting them to brake loose. I see that you are in colorado, and if my motor wasnt down I would have come down to help you out, well good luck with the bolts
Old Jun 17, 2006 | 03:13 PM
yep, i do live in colorado. thanks though. i work at home depot so gettin a breaker bar is no prob.
Old Jun 17, 2006 | 04:29 PM
ripperbone's Avatar
get about 2 feet of steel piping, works wonders for leverage on breaking bolts loose
Old Jun 17, 2006 | 05:37 PM
I've started to twist a bolt with a breaker bar before and then took an impact gun to it and it came right off. I've broken many a bolt heads off with breaker bars. Panther **** sure helps though.
Old Jun 23, 2006 | 03:28 PM
ok, the head is off! not liking what i am seeing though: flaking on the tops of the pistons. it's time to start rebuilding!
wood 1
13
Jun 4, 2006 09:01 PM
RACEPAK
11
Oct 7, 2005 12:12 PM
_Cyclone_
10
May 16, 2005 01:15 PM
grngsr01
Jun 15, 2004 07:14 PM
sacredc0w69
Apr 13, 2004 08:50 PM
