which tool do i need to use to loosen head bolts ? ? ?
Old 10-07-2005, 10:22 AM
RACEPAK's Avatar
Default which tool do i need to use to loosen head bolts ? ? ?
hello everybody.
whats the propar way to loosen the head bolts?
impact wrench?
braker bar?
tourqe wrench?
i tryed with a normal wrench but it seems too hard.
TIA
Old 10-07-2005, 10:23 AM
Luserkid's Avatar
Default Re: which tool do i need to use to loosen head bolts ? ? ? (RACEPAK)
I use my Air gun. Before that i used a 1/2inch ratchet with socket and a 3 foot cheater.
Old 10-07-2005, 10:25 AM
RACEPAK's Avatar
Default Re: which tool do i need to use to loosen head bolts ? ? ? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I use my Air gun. Before that i used a 1/2inch ratchet with socket and a 3 foot cheater. </TD></TR></TABLE>
you lazy basterd.... taking off valve cover bolts with a impect, LOL
Old 10-07-2005, 10:27 AM
Luserkid's Avatar
Old 10-07-2005, 10:28 AM
RACEPAK's Avatar
r u sure that its ok using a air gun on the head?
i heard some bad stories about it....
Old 10-07-2005, 10:32 AM
Luserkid's Avatar
What stories?
I have never heard of a headbolt ever breaking or snapping or anything. Only thing i heard was stretching when there reused but thats something else. Also i heard about stripping the insides.
If your really paranoid about it do the cheater bar trick and just listen for it. Youll hear a load snap and thats when you know it broke loose. First time i heard it i almost **** my pants its so loud and sounds like breaking a bolt
Old 10-07-2005, 10:34 AM
RACEPAK's Avatar
THANKS...!!
Old 10-07-2005, 11:11 AM
1bad-eg's Avatar
Air impact all the way
Old 10-07-2005, 11:18 AM
Imperious: Mod of Valor
JDM-EJ1's Avatar
Damn, Victor that's crazy.
Old 10-07-2005, 11:34 AM
HondaFanatic708's Avatar
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: which tool do i need to use to loosen head bolts ? ? ? (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Factory Service Manual &raquo;</TD></TR><TR><TD CLASS="quote">
CAUTION:
To prevent warpage, unscrew the bolts in sequence 1/3 turn at a time; repeat the sequence until all bolts are loosened.
You would want to loosen them in a criss-cross pattern working from the outside in. Don't know about anyone else, but I would rather take my time than risk replacing a warped head. You want the torque on the head to be released slowely and evenly. Completely loosening one bolt at a time puts stress on the head. I've always used a 1/2" drive rachet and put some muscle in it. Never had a problem here even with the block out of the car.
Old 10-07-2005, 12:06 PM
RACEPAK's Avatar
Default Re: which tool do i need to use to loosen head bolts ? ? ? (HondaFanatic708)
DAMN... i tryed to use a 15" braker bar and it seems impossible.
also what socket do you use? a deep one or a regular one.?
it seems that the deep socket is leaning on the journal
Old 10-07-2005, 12:12 PM
Deep impact sockets but again just on a rachet. Just put one hand at the pivot to control it. I've also found that pulling as opposed to pushing is usually easier.
dustin
Engine Machining & Assembly
27
01-10-2018 11:41 PM
Tong.Y
32
02-01-2011 02:05 PM
motorhead_ls
06-23-2006 03:28 PM
SPEED123
11-29-2003 12:49 PM
Quick Reply: which tool do i need to use to loosen head bolts ? ? ?
