Bouncing Speedometer guage
Old Jun 16, 2006 | 08:07 AM
TurboEM1's Avatar
Default Bouncing Speedometer guage
Hey guys I have a stock 91 CRX Si and the mph gauge bounces up and down when you accelerate and even when you are just cruising. What causes this? Its super annoying and looks stupid. Thanks
Old Jun 16, 2006 | 08:13 AM
Loserkidwac's Avatar
Default Re: Bouncing Speedometer guage (TurboEM1)
Speedo or Tach? if speedo then its probably a bad VSS or the cable isn't pushed in all the way...if you ment tach then check the connections on the back of the cluster and in the dizzy...
Old Jun 16, 2006 | 08:18 AM
TurboEM1's Avatar
Default Re: Bouncing Speedometer guage (Loserkidwac)
speedo
Old Jun 16, 2006 | 08:56 AM
1989CivicSi's Avatar
Sounds like bad VSS or bad VSS solder connections (inside cluster). I had the same problem for a while because I ghetto-rigged the stock cable-driven VSS unit from the original cluster to work with my JDM SiR cluster (I.E. ripped the **** out of the VSS in the original cluster and re-soldered it for use with the JDM cluster).
Cliffnotes: Sounds like your VSS or some connections are going out.
Old Jun 16, 2006 | 09:13 AM
thesmogman's Avatar
Mine cable started to come out of the hole. Just push it back into the tranny.
Old Jun 16, 2006 | 11:26 AM
TurboEM1's Avatar
Default Re: Bouncing Speedometer guage (thesmogman)
also it only does it under 40mph. once you get on the parkway its fine. Ill look at the VSS and let you guys know. Thanks
Old Jun 16, 2006 | 11:28 AM
nappyroots827's Avatar
my old accord used to do that at low speeds, i think it was just the cluster, most likely ure just gonna need a new cluster/speedo assembly
Old Jun 16, 2006 | 11:37 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
It is most likely the speedometer cable..
What causes this is that the speedo cable is dry inside and
it begins to bind up causing a condition known as "whipping"..
This condition is usually accompanied by a
constant "wick-wick-wick" sound..
See: https://honda-tech.com/zerothread?id=1325930
for information on lubricating the cable..
siregcivic
Oct 10, 2011 10:43 AM
lopezchris21
Sep 18, 2008 11:40 AM
Phil_SiR
Jan 30, 2007 07:21 AM
hondaboy4life
Oct 9, 2006 09:35 AM
Built B18ABorC
Oct 26, 2004 05:41 PM
