BLACK OILY CRAP in my TB!!
Old Jun 15, 2006 | 08:41 PM
MRturbo's Avatar
Default BLACK OILY CRAP in my TB!!
Well i just got my engine and there is BLACK OILY CRAP that smells like gasoline in the TB and as far as i can reach into the TB. WTF is this crap?? is my engine fucked already??? Feels like oil but smells like gasoline!! Normal??
Old Jun 15, 2006 | 08:43 PM
SlamminS85's Avatar
Default Re: BLACK OILY CRAP in my TB!! (MRturbo)
if you have a leaky valve seal and a chipped valve you can blow both gas and oil around... and depending on the car it can go right to the TB...
Old Jun 15, 2006 | 08:45 PM
MRturbo's Avatar
Default Re: BLACK OILY CRAP in my TB!! (SlamminS85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlamminS85 &raquo;</TD></TR><TR><TD CLASS="quote">if you have a leaky valve seal and a chipped valve you can blow both gas and oil around... and depending on the car it can go right to the TB... </TD></TR></TABLE>
i just got this motor on wedensday! 97 JDM B18C. think i got a bad motor??
Old Jun 15, 2006 | 08:52 PM
watsvtecEK's Avatar
Could be exesive blowby, check your pvc valve. if it is blow by then its your rings or ringlands. some oily residue is normal but not alot.
Old Jun 15, 2006 | 08:54 PM
MRturbo's Avatar
Default Re: BLACK OILY CRAP in my TB!! (D 2da A9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">Could be exesive blowby, check your pvc valve. if it is blow by then its your rings or ringlands. some oily residue is normal but not alot.</TD></TR></TABLE>
there is a lot!! i stick my hand in there and pull out and my whole hand is cover in oily crap that smells like fuel.
Old Jun 15, 2006 | 08:58 PM
watsvtecEK's Avatar
bump for more for you, but take the breather tube off your intake and see if it is putting out smoke or if it is just putting out alot of air, also the tube that goes from the valve cover to the intake manifold take that off the intake mani and see if it is blowing out smoke also, but connect them up again before driving it.
Old Jun 15, 2006 | 09:01 PM
MRturbo's Avatar
well the thing is the engine is still on the pallet...just got it on wedensday. I took the intake off and looked inside and it is all covered with oily crap. Took a look inside the TB and same ****!!! MORE INFO!!
Old Jun 15, 2006 | 09:08 PM
watsvtecEK's Avatar
i dont think you will be able to see what is exactly wrong until you start it up.
Old Jun 17, 2006 | 01:24 AM
SlamminS85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MRturbo &raquo;</TD></TR><TR><TD CLASS="quote">there is a lot!! i stick my hand in there and pull out and my whole hand is cover in oily crap that smells like fuel.</TD></TR></TABLE>
you must have a tiny *** hand
pjr710
15
Aug 12, 2007 05:12 AM
PWRDbyHseries
Mar 11, 2007 04:53 AM
ITR198
May 7, 2006 08:36 PM
huepowered
Apr 4, 2006 12:10 PM
happy_guy
58
Sep 22, 2005 10:26 PM
