realistic hp and boost
im going to get tuned on the 22nd and was asked how much boost im going to run ? i have a fully built lower end w stock sleeves , je 9;1 pistons, crower rods honda bearings, balanced and blueprinted ect , and block guard , also i will be tuning on a stock head. dp is 2.5 , exaust is 2,3/4 , 3bar map, 880cc injectors 55lph fuel pump aem fuel rail and regulator, sk2 pro intake manifold ,turbonetics .57 .63 ar t3to4e . clutch is stage 3 six puck, flywheel is 8 lbs. is 17 psi too much??????????
Modified by 94integragsr at 6:04 PM 6/15/2006
I got about the same setup and I put down 365@14 psi on pump with a very conservative tune. Stock head and DP are going to be factors though. should make about 400 whp on 18psi on your setup.
crx88fast
10
Apr 7, 2005 05:07 PM
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
