Sleeved b16
Rebuilt B16A. Sleeved w/ Darton Sleeves, JE9:1 Pistons, Eagle Rods, King Bearings, Eagle LS Crank, ARP Main bolts. Bored to 84mm / Stroke 89mm.
Would I be able to make over 500 hp with this set up. If so what turbo should i use. I am a lil new to boost with these kind of power levels, I am more familiar with simple set ups on ls blocks
i am 84mm b16, stock b16 crank, i made 520 with no timming on a t3t67 ho .70/.82 at 27 psi. the engine is 3 years old and very tired. went 10.96 with that added 4* timming, and went 10.72 never got it back on the dyno, we are guessing about 540 with that. once the axle gets here, gonna throw another few * at it and up the boost to 30 +- and see where it goes.
but to answer your question, yes 500 is attainable on your setup.
the turbo depends on where you want your power. my setup i have a very narrow powerband. look at a 35r or a big 30r.
some have gotten away with a stocker, others an OBX, but my money is in my quaife. i will not go with any other, other than a full spool. but i am not ready for that yet.
h22a193
Nov 11, 2003 05:44 PM
