Creeking front right suspension
Old Jun 14, 2006 | 05:11 PM
Coupe-R's Avatar
Default Creeking front right suspension
I have been struggling to find short cheap shocks for my da integra so I can have it a resonable height and still have travel.
I had neuspeeds Springs in there and they were under so much tension i cldn't line up the top hat very good with the two bolt holes. So i twisted the bottom fork as hard as i cld and quickly put the bolt through.
Now the car creeks like and old creeky chair or door, this is under braking only.
It wlda put massive twisting strain on the LCA bush do u guys think its this??
P.S I changed to BA5 prelude short shocks and coilovers so no more tension and everything lines up nice but still creeking. is it still safe to say iv screwed the right front LCA bush?
Modified by Redinteg at 2:43 AM 6/15/2006
Old Jun 15, 2006 | 01:08 AM
Coupe-R's Avatar
Default Re: Creeking front right suspension (Redinteg)
ah i searched and like only 1 topic that applies.
so anyone got a 2nd opinion on this?
Old Jun 15, 2006 | 08:13 AM
Sam92Teg's Avatar
Yes, you didn't orientate the top hat and spring to match the top bolt holes. Sounds like you just placed the top hat on the spring and tried to bolt up, it must be placed on the spring in the right position to fit correctly. Don't feel bad, I almost did the same thing when I installed my springs.
Old Jun 17, 2006 | 10:29 PM
Coupe-R's Avatar
Default Re: Creeking front right suspension (Sam92Teg)
ah yeh but thats not my creeking problem
I have since changed the suspension if u look above, and everything is lined up well. Im set that its the LCA bush, just wanted opinions
Old Dec 16, 2008 | 02:35 PM
Gvis420's Avatar
Did you find the problem?
Old Dec 16, 2008 | 03:14 PM
ACTION JACTION's Avatar
Do you have any kind of camber correction, ingalls mount type or adjustable upper control arms? My guess would be those bushings, they need to be greased up well.
Old Dec 17, 2008 | 06:06 AM
Gvis420's Avatar
I found alot of people asking the same question but nobody knows or they dont care. Ive never been able to find any answers.
Old Dec 17, 2008 | 06:32 AM
Grease your Upper control arm mount bushings!
Old Dec 17, 2008 | 08:27 AM
Gvis420's Avatar
Its coming from the top of the shock. Ill try lubing that up.
YoungKadafi
12
Dec 15, 2006 08:01 AM
londonsupra
Jul 4, 2006 05:14 AM
2LoW4FaThOeS
Honda Civic (2001 - 2005)
Apr 3, 2006 09:55 PM
accordfamily
Nov 17, 2004 08:49 PM
psdvette
Sep 21, 2003 12:53 AM
