Need help?
Old Jun 14, 2006 | 03:25 PM
Civic Hybrid's Avatar
Default Need help?
I have had an idle issue for a while so i did some searching on here and got as far as figuring it out. The fitv is my problem. I did the "cover the hole in the TB test" and it was sucking air when the motor was completly warm. It was sucking hard too. Im confused as to how you go about getting the fitv to come off. All the searching I did shows people taking it off with there IM off. I just want to tighten the screw inside there and put it back on. It just seems so complicated to get under the TB. If you are trying to tighten the screw wat is the easiest way to start the removal of the fitv???
Old Jun 14, 2006 | 08:27 PM
qfast817's Avatar
Default Re: Need help? (Civic Hybrid)
i took the whole tb off
Old Jun 14, 2006 | 10:03 PM
Default Re: Need help? (qfast817)
I see....thats wat i was thinkin about doin. Don't you need to get a new TB gasket then?
More peoples experience are greatly appreciated. C'mon idle people you no wat it was once like!
lude-tec
Mar 14, 2006 08:03 PM
ITRacer121
11
Mar 25, 2005 01:49 PM
SpoolnG2
Oct 18, 2002 05:11 AM
One8Hatch
Oct 23, 2001 07:16 PM
