oil blowing in engine bay
Old Jun 14, 2006 | 03:13 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default oil blowing in engine bay
i have a 91 ls integra and recently my engine has been smoking, white and i think blue smoke. i have checked the compression and it was 180 175 180 180. for like the past 2 weeks there has been oil spraying into the engine bay. I think it is spraying from the the black box that the pcv hooks to. It is a new pcv, but the side that hooks into the box is the wrong size of something.
the pcv has been unhooked i guess for about 3500 miles. i didnt know.
need some opinions.
and yes i have searched for about 3 days
was thinkin it was either Head gasket, rings, or valve seals.
someone help.
Old Jun 14, 2006 | 05:22 PM
JSPECSIR's Avatar
Default Re: oil blowing in engine bay (turbob16EF)
di you check to make sure its not blowing out of the vent on the valve cover.
Old Jun 15, 2006 | 06:55 AM
turbob16ef's Avatar
Default Re: oil blowing in engine bay (JSPECSIR)
yeah i have check it also blows out of there along with the box for the pcv. i am pretty sure it is the rings just trying to make sure and get someone elses opinion.
thanks
Old Jun 15, 2006 | 03:39 PM
PwrspdAllMotor's Avatar
Pretty sure that its not the rings compression is pretty good on the LS . I would hook the pcv back up it is designed to help releave the crank pressure.
Old Jun 15, 2006 | 10:09 PM
turbob16ef's Avatar
Default Re: oil blowing in engine bay (pwrspdB20v)
i am getting another new pcv tomarrow and all new fitting, hopefully that will help. but i think the valves seal are already shot. plus i gotta another head that i ready to be put in, i am just trying to figure what the problem is before i boost it again.
i am building another block for the car just not sure of brands, probly cp pistons and eagle rods, 10:2 comp.
Old Jun 16, 2006 | 10:36 AM
turbob16ef's Avatar
anyone else have an opinion on what it is
Old Jun 16, 2006 | 09:57 PM
I had the same problem with mine. Sorry I didn't read the whole thing. What was happening with mine was I was building up to much crank pressure and the only place it had to go was out of the valve cover. I put a breather kit on it from Endyn and since have had no problems, theres a link at the bottom if ya wanna check it out.
http://theoldone.com/components/breather/
Old Jun 17, 2006 | 05:13 AM
turbob16ef's Avatar
alright thanks, i was planning on buying a catch can any way once i throw my turbo kit on. i guess i will go ahead and buy one.
Old Jun 17, 2006 | 10:05 PM
Not a catch can, that just catches oil. The breather kit actually screws into the back to the block in different locations and replaces the breather box to releave the pressure I put in on my LS on boost
Old Jun 18, 2006 | 02:45 PM
turbob16ef's Avatar
oh well then i will be sure to buy one with a breather to
thanks for the help and replies
hondamatt89
Mar 17, 2015 11:19 AM
90datech
May 13, 2008 07:10 AM
2 0 3
Sep 7, 2006 03:02 PM
JDMbull
Aug 3, 2006 08:48 AM
vtec_racer_2kgsr
Jul 17, 2002 05:28 PM
